[ROM][WIP][ALPHA][NS4G] oICSv43 | AOSP 4.0.3 (ICS)
Paul627g
AC Moderator All-Star
Moderator
Nov 25, 2010
15,958
2,752
Source/Link: [ROM][WIP][ALPHA][NS4G] oICSv43 | AOSP 4.0.3 (ICS)
Designer: AOSP
Changelog for v43
CM9 Notification Power Widget added
Alpha CM9 Settings added
Fix file downloads via browser over WiMax thanks burnsra
Browser fixes
Networks fixes
App Cleanup
SMS fixes
Face Lock added
More Stability tweaks
more..
Happy Holidays and a New Year All the Best from aosp :)
Changelog for v41
Fixed missing bins
Less FC's ;)
Updated apps
More stability
More Wi-Fi fixes
Highly suggest a full wipe ;)
more..
Changelog for v40
Superuser fixed
Performance tweaks
Flash fixed
SMS fixes
Wi-Fi fixes
more..
Changelog for v36
Updated and built off AOSP v4.0.3 ! (Whole new ballgame here folks..)
[TIP]*** Added Bonus a 1% battery mod over stock theme... Courtesy of yours truly... Paul627g
Download : Stock Theme CM Style Bat Mod (Flash in CWM, wipe dalvik cache)[/TIP]
### Previous oICS builds based BEFORE official AOSP 4.0.3 Source ###
Changelog for v29
CM9 T9 Dialer added
Force close issues fixed
More Tethering fixes
Updated ICL53F Gapps
Updated Kalikernel
More stability tweaks
Changelog for v27
Updated Kalikernel
Changelog for v26
12/9 franco.kernel added
Tethering fixed
GPS fixes
Data caps fixed
Speed improvements
Changelog for v25
Updated Kali kernel with many changes
Optimized user build
Updated Apps
Backup cloud fixed
No more red borders
Changelog for v23
Rebased to android-4.0.1_r1.2
Updated ITL41F Gapps
Kalimocho Kernel with Wifi changes for bcmdhd
AdAway more ;)
No credit taken here... Just passing along.. Enjoy !
Re: [ROM][WIP][ALPHA][NS4G] oICSv19 | AOSP 4.0.1 (ICS)
Didnt it jump from 13? Not that I'm complaining but I thought I was staying on top of that one.
Is anyone else unable to change the live wallpaper?
14 thru 16 must have been test or beta builds that didnt make public... Thats all I can figure..
I can switch live wallpaper just fine, my problem is that it is not picking up my Picasa albums in the Gallery app. It seems to be affecting others as well.
I was trying to change to one of the static wallpapers and couldn't do it at the main screen level. Could change from one live wallpaper to another live wallpaper, but not to a standard wallpaper. But when I went in through the settings menu to display -- wallpapers, I was able to select a static wallpaper that way.
I know there has been some good improvements "behind the scenes" in this newer build. Many apps I couldn't run before are now running and its not because they were updated by the app manufacture because I restored them from My Backup Root.
So a big thumbs up on this build so far. Plus I really dig the additional extended power menu options... Very clean and efficient.
V21 fixes the google music streaming issue and re-enables galllery photo syncing that were issues in V19.
Can anyone get this alleged build 21 to download? I can't.
Yep... Could be a bandwidth problem.... So many people downloading it the server is getting over loaded...
Re: [ROM][WIP][ALPHA][NS4G] oICSv21 | AOSP 4.0.1 (ICS)
You should have the threads merged
Sent from my Nexus S 4G using Tapatalk
Old thread has been closed by the mods. I will update the OP in this thread for any future updates to this build.
I still can't get it to dl. Goes through all the motions, and then says download unsuccessful after it gets to 100 percent
You downloading to computer or device?
Device. But I just now downloaded to computer. We'll try it that way.
I NEVER download ROMs directly to my device...
1. Takes to long even on WIFI or solid 4g
2. Problems like your having when the download fails at the end
3. Download goes through only to find out the file is corrupt or has a few bad bytes or something in it during the download.... Packet loss during transfer...
4. As Blackhawk mentioned.... Certain file types won't download on stock or stock browser... Dolphin usually gets around that...
Always download to computer then transfer it over.... Less headaches.
Dugoh1
