Results 1 to 5 of 5
- 07-04-2012, 01:00 PM
Thread Author #1
PLEASE HELP!?!? I edited my build.prop wrong...
Okay, I edited my build.prop file so it matched a galaxy nexus and then rebooted my phone... but it won't turn on right, it shows the google thing and then a black screen. I have a backup of the original build.prop on my phone, so what I need is a way to manipulate files from my computer WITHOUT having to mount the USB storage. Please somebody tell me there's a way to fix this...
Additionally, I tried to go into clockwork recovery to mount usb storage, but when push 'recovery' form the bootloader it just kicks me back to the bootloader.
My phone is a paperweight until I fix this, so I greatly appreciate whatever help you guys can give me. - 07-04-2012, 02:57 PM #2
Re: PLEASE HELP!?!? I edited my build.prop wrong...
Check out oneclickstock posted in the forums. It should take you back to brand new status. Phone just needs to be connected I believe.
- 07-04-2012, 03:18 PM
Thread Author #3
- 07-04-2012, 03:59 PM #4
Back out of this thread and look at the very top of the forum page. There are stickies up there and one of them is the one your looking for.
- 07-04-2012, 05:45 PM
Thread Author #5
Got it, thanks
However... I am reluctant to wipe it and do a factory reset. I was pretty far in Super Mario 64 :P I am going to take it to a cell phone service center and see if they can restore my build.prop or if they will look at me like I'm crazy. If the latter occurs... I have alot of Super Mario to catch up on
Thanks for the help guys
Reply
