1. 6tr6tr's Avatar
    Anyone know if/when CM9 will add in the wimax radio and other stuff now that Nexus S 4G is AOSP again?
    07-05-2012 11:04 AM
  2. charn65's Avatar
    My 4g works on CM9 already. Which one are you using?
    If you haven't tried it, give the CM9 release a couple posts down a shot. Its pretty solid, and great battery life.
    Good luck!
    Sent from my Nexus S 4G using Android Central Forums
    07-05-2012 02:20 PM
  3. 6tr6tr's Avatar
    Good luck!
    I was going off this: http://forums.androidcentral.com/spr...ml#post1898834
    BTW, are there any features that do not work?
    07-05-2012 02:30 PM
  4. charn65's Avatar
    For what I'm using it for, I can't find anything that doesn't work. Worth a shot, and I'm using 4g now to post this.
    giograves likes this.
    07-05-2012 02:32 PM
  5. DeathsArrow's Avatar
    4G has always worked on CM 9.
    07-05-2012 03:16 PM
  6. aman1127's Avatar
    Won't happen for a while on jellybean though. We would have to wait for an official OTA for that to extract the carrier binaries
    Sent from my Nexus S 4G using Tapatalk 2
    07-15-2012 02:05 AM
