1. 6tr6tr's Avatar
    Anyone here using cyanogenmod 9 rc2? I'm wondering if it's all working or if there's still issues that need fixing.
    07-25-2012 09:35 AM
  2. Paul627g's Avatar
    I think everyone who is rooted has been trying out JB.
    I'm sure you will still find people using this ROM and other ICS based ROMs but the main focus is naturally on JB.
    I see CM10 moving along very quick once it goes from unofficial to official status.
    07-25-2012 10:24 AM
  3. DeathsArrow's Avatar
    RC2 is solid, no issues as far as I can tell. There are a few nightlies beyond RC2, but the changes are very minor.
    There also hasn't been a new nightly since 7/23, which likely means the stable version is coming.
    07-25-2012 10:43 AM
  4. Mordac's Avatar
    I've been using the nightlies for a while, but stuck with RC1 until I saw that RC2 was out.
    The *only* issue I had with RC1 was an occasional oddness with the wireless disapearing. A reboot fixed that.
    I have had no problems with RC2 yet.
    -M
    07-25-2012 11:17 AM
  5. Paul627g's Avatar
    Until JB ROMs started to pop up, CM 9 RC1 was my ROM of choice since they released the "RC1".
    Very stable... I really can't see what they had left to fix.
    07-25-2012 12:59 PM
  6. 6tr6tr's Avatar
    Not to get too off-topic but, does JB really make a difference in responsiveness on the NS4G? Is it noticeably faster to where it feels like a new phone?
    07-25-2012 04:35 PM
  7. DeathsArrow's Avatar
    The CM10 experimental build is very smooth other than Google Now will sometimes stutter when you load it.
    07-25-2012 04:49 PM
  8. Paul627g's Avatar
    Yes jelly bean has a very noticeable difference in smoothness and over all responsiveness when compared to even some of the better ICS ROMs.
    Sent from my Nexus S 4G using Android Central Forums
    6tr6tr likes this.
    07-25-2012 06:14 PM
  9. 6tr6tr's Avatar
    That's really good to hear! I wasn't sure how big of a difference it would make on a single CPU device without a ton of RAM and a so-so GPU.
    07-25-2012 10:34 PM
  10. Paul627g's Avatar
    Yes it does make a big difference... I'm sure the dual cores and better supporting hardware run and benefit from JB much better but it is still a very noticeable difference even on our little old NS4G's...
    07-25-2012 11:42 PM
  11. 6tr6tr's Avatar
    Now if only CM10 would reach final release...
    07-26-2012 04:46 PM
  12. Paul627g's Avatar
    LOL.. I think were a ways from that but I can see it moving very fast once official source is dropped by Sprint/Sammy for JB on the NS4G. CM won't touch it "officially" until then.
    07-27-2012 10:11 AM
  13. Xiphos16's Avatar
    im having a problem on rc2 bluetooth. it won't turn on. -_- any way to fix this?
    10-07-2012 08:27 AM
