DEAL OF THE DAY: Save 37% on the Seidio SURFACE Case for Samsung Galaxy S4!
Results 1 to 10 of 10
    Default [INFO] CM10 Nightlies for Nexus S 4G
  2. #2
    Default Re: [INFO] CM10 Nightlies for Nexus S 4G
    Gapps?
  3. #3
    Mordac's Avatar
    Posts
    Global Posts
    72 Global Posts
    Quote Originally Posted by the727kid View Post
    Gapps?
    Currently, the most recent Gapps for CM10 is , but that may change. Best to look at the Wiki page for up to date info.
    -M
  4. #4
    I'm new to the nightly thing. Every time there is a new build, does that mean there are new features and changes to the ROM? Or improvements?
  5. #5
    skinneejay's Avatar
    Posts
    Global Posts
    729 Global Posts
    ROM
    Peter's Bugless Beast ICS
    All of the above. Improvements are made, new features added, bugs stomped out, code cleaned up. You don't always have to update after each new nightly is release. You can skip one here and there. After the nightlies comes the stable builds, then finally the Release version.
    Quote Originally Posted by moonoverparma00 View Post
    Personally, I stay away from nightlies on my main phone as I need it to work perfectly and keep my data for work. The nightlies do always bring bug fixes, etc but can also bring new bugs as well so it's always a risk.
  7. #7
    Default
    I upgraded from 806 to 820, I will update if it gets into 30's, so simple. Do miss rotation in browser, but this is temporary
    Sent from my Amazon Kindle Fire using Tapatalk 2
  8. #8
    Default
    I'm running 28 and I like it, what has changed in 30 that I might want to install?
    sent from Amazon Fire running jellybean with taptalk2
  9. #9
    chud's Avatar
    Posts
    Global Posts
    2,342 Global Posts
  10. #10
    Default
    Thank you most useful information.
