Results 1 to 5 of 5
    corolla90's Avatar
    Posts
    Global Posts
    252 Global Posts
    ROM
    CM10
    Default Contacts Issue, No area codes pulling up - Currently Running CM10 Nightlies on NS4G
    Hey guys,
    I can't really pinpoint exactly when I noticed this, but I'm pretty sure it has been an issue ever since I flashed CM10 on my NS4G. The issue I'm having is that for the majority of my contacts, the main phone number is indented 2 spaces. So what ends up happening is that when I open up the stock SMS app and I type in their name and I select them from the list, it pulls up the phone number, but not the area code. So then I send a message, and I get a message back saying the message could not be sent, which makes sense because the area code wasn't there.
    Has anyone else experienced this? If so, have you found a fix? Is this a CM10 issue? A JellyBean issue?
    Thanks in advance for any help or insight.
  2. #2
    hlxanthus's Avatar
    Posts
    ROM
    RasbeanJelly/DanteRom v4
    Honestly, no I have not. But I have always imputed phone numbers like this xxx-xxx-xxxx, no 1 no +1 etc. I don't know why you have the extra spaces, but to me the obvious fix would be to go thru your contacts and fix them. Of course if you an uber-ton of contacts that could take a while. The best way to do that would be thru your web browser to change your contacts directly, then resync your phone.
    corolla90's Avatar
    Posts
    Global Posts
    252 Global Posts
    ROM
    CM10
    Default Re: Contacts Issue, No area codes pulling up - Currently Running CM10 Nightlies on NS4G
    Yeah, I mean, the strangest thing is that this all occurred after I flashed CM10. Contacts before were fine. And the issue really only occurs with SMS ... not with calling people. Oh well, I may just have to go through and fix them manually.
  4. #4
    I'm having the same issue. And I don't have my contacts listed with a 1 in the front. Only the 800 numbers. Most of mine are (xxx) xxx-xxxx.
    Any help would be appreciated. I could go through and change them but it only started happening with cm10.
  5. #5
    Did u evr get a fix for this issue? I think the point people are missing is that it happens also when I get a missed call from a number that isnt saved in my phonebook. I tend to text the person that Ill call back later, The text wont export the area code to the SMS app, and thus wont send the text properly. Is there a fix?
  1. Pull up contacts from stock dial pad?
    By chriscw81 in forum Verizon Galaxy Nexus
    Last Post: 07-20-2012, 12:44 AM
  2. Area Code Text Issues
    By StormColorado in forum General Help and How To
    Last Post: 06-12-2011, 01:30 AM
  3. No Pics When Pulling up Internet
    By bboats in forum AT&T Inspire 4G
    Last Post: 05-05-2011, 01:07 AM
  4. DX is no longer dialing area code
    By jasoncardenas21 in forum Motorola Droid X
    Last Post: 09-03-2010, 01:07 PM
  5. WEIRD contact issue-- doesn't show up in messaging?
    By ali.fazal in forum Motorola Droid
    Last Post: 01-31-2010, 10:13 AM
