Results 1 to 8 of 8
    kalex's Avatar
    Posts
    Global Posts
    717 Global Posts
    ROM
    Original 2.3.4
    Default How TO get battery icon with numbers on NS4G
    I just changed my battery icon to display accurate numbers.
    This works on stock ROM. My NS4G is rooted and has clockwork on it only, no custom ROM
    here is how:
    1)make sure you are rooted and have clockwork recovery installed
    2) go to UOT Kitchen
    3) Click on battery Tab. Click on enable this mod
    4) choose your options. I went with gingerbread option
    5) Click on file upload tab. You will need to upload 2 files from your phone. I used ES file exploer to get the files and upload them to my computer via LAN connection. Files are:
    /system/framework/framework-res.apk
    /system/app/SystemUI.apk
    Upload both files to the UOT kitchen
    On the left side of the upload page, leave everything default.
    Click the summary page, check your settings, Donate and click submit work to kitchen.
    Wait until you get the file. Download the file and save it to SD card on your phone.
    6) Boot into bootloader and select recovery
    7) DON'T SKIP THIS. MAKE A FULL NANDROID BACKUP BEFORE YOU PROCEED WITH FLASHING
    8) Wipe cache and davlik cache in recovery.
    9) flash the zip file that you got from the kitchen and reboot the phone.
    10) Enjoy your fishing
    Attached Thumbnails Attached Thumbnails How TO get battery icon with numbers on NS4G-snap20110517_120309.png
  2. #2
    Default
    Thank you for this now I can play w the status bar!!!
    Evo 4G --> Nexus S 4G
  3. #3
    jeffreynothing43's Avatar
    Posts
    ROM
    Stock Rooted
    Default
    This isn't working for me...I followed it to a T.
    kalex's Avatar
    Posts
    Global Posts
    717 Global Posts
    ROM
    Original 2.3.4
    Default
    what part are you having trouble with?
  5. #5
    Default
    Thank you.
  6. #6
    Posts
    ROM
    Stock Rooted
    Default
    Quote Originally Posted by kalex1114 View Post
    I guess I didn't do anything wrong...I just tried it a few times and then it worked. It didn't like my laptop but worked on my PC. Thanks for this.
    kalex's Avatar
    Posts
    Global Posts
    717 Global Posts
    ROM
    Original 2.3.4
    Default
    Cool
  8. #8
    nmoreman's Avatar
    Posts
    Global Posts
    764 Global Posts
    ROM
    aosp v41 (until he update
    Default
    Or if this doesn't work for you, and I'm chicken which is okay, found an app in the market - simple battery
    that puts an accurate, non battery draining number on top. Do not like the standard and had these on rooted Epic. This is working well for me.
