1. bjones521's Avatar
    I am updated to 2.3.5 yet I seem to only get service at work(huge office building). When I walk outside i barely get 1 bar. When im at my home I get maybe 1 bar of wifi and one bar of data.
    Please!! What can i do to make my speed better and give me more bars? Anything!!
    Thank You
    08-03-2011 12:25 PM
  2. Shabbypenguin's Avatar
    there is nothing we can do to help you, except maybe tell you to check out roam control and see if verizon offers better signal for ya. the one downside is that youll be roaming so if you use too much data sprint will throw a tizzy and threaten to cut you off
    08-03-2011 12:57 PM
  3. bjones521's Avatar
    Check out roam control?? How do you do that?
    08-03-2011 01:13 PM
  4. shazadm's Avatar
    Go to settings, then touch wireless newtworks. Then go to mobile networks at the bottom. You should see somethings about roaming. I am pretty sure that is how you control roaming.
    08-03-2011 06:01 PM
  5. |-KGB-|CaptHowdy's Avatar
    roam control is an app for rooted phones that will force the phone to roam vs roaming set to available.
    08-03-2011 06:19 PM
  6. bjones521's Avatar
    Thanx but roam control didnt work! Guess I'll troubleshoot some more!
    08-04-2011 10:09 AM
  7. chud's Avatar
    Have you tried going back to 2.3.4?
    08-04-2011 10:21 AM
  8. bjones521's Avatar
    No, I didnt know how. Do I need to be rooted for that?
    08-04-2011 12:49 PM
  9. chud's Avatar
    You're not rooted?
    08-04-2011 12:55 PM
  10. bjones521's Avatar
    You're not rooted?
    Of course. Yes im rooted.
    08-04-2011 03:30 PM
  11. 6tr6tr's Avatar
    Dumb question, but have you restarted a few times since you installed the update? I found it got a bit better after a restart (not 4G, that still sucks, but 3G).
    08-04-2011 03:43 PM
  12. chud's Avatar
    I would definitely try this first, but go a step further and just pull the battery for a few minutes.
    Just making sure before I tell you to download the 2.3.4 zip and the corresponding radio to your phone and then reflash them through Clockword Mod.
    08-04-2011 04:42 PM
  13. bjones521's Avatar
    Yea I tried that....doesnt work smh. how can i download 2.3.4?
    08-04-2011 06:38 PM
  14. chud's Avatar
    08-04-2011 07:01 PM
  15. bjones521's Avatar
    Ok thanx Shud I appreciate you helping but Im somewhat of a noob. Should i download Odexed or DeOdexed. Also should i download the software images and the radio too? if so...which one?
    08-04-2011 07:57 PM
  16. chud's Avatar
    GRJ22 Stock Rooted ROM and D720SPRKD8 Radio are 2.3.4 and the radio for it. Generally deodexed is what is recommended for speed. I can go into the two options more if you'd like regarding what each one means, but that's really all it boils down to in the end.
    08-04-2011 08:28 PM
