1. evilhugbear's Avatar
    Hey guys,
    I noticed in the wireless tether app, it shows the battery temperature. How hot is too hot for tethering? 45C? 50C?
    Thanks!
    08-03-2011 03:42 PM
  2. enik's Avatar
    I really try not to go over 104 f which if my math is any good would be 40 c. Don't know if you can safely run higher but I try not to.
    From Nexus with love
    08-03-2011 04:51 PM
  3. shazadm's Avatar
    I'm not too sure about a safe temperature. Anything over 100 seems bad to me. My nexus s 4g stays at around 36 degrees Celsius
    08-03-2011 04:52 PM
  4. Paul627g's Avatar
    Yes that sound about right... I've had my battery heat up pretty hot at times then return to normal with no damage. Certain things we do at times cause a phone to really heat up. Also phones normally have a built in protection that once they get to a certain temp they will shut down to protect themselves.
    08-03-2011 05:06 PM
  5. evilhugbear's Avatar
    Okay, thanks guys
    08-03-2011 08:54 PM
