Results 1 to 4 of 4
    Default sound issues
    Is there anyway I can just have my volume for incoming calls on and keep my notifications on vibrate? I'm an on call worker and I leave my phone on vibrate because I'd like to have the ringtone for calls on and all the other crap off? Thnx in advance
  2. #2
    Default Re: sound issues
    In settings do not assign any tone for the incoming notifications such as sms.
  3. #3
    I tried a volume enhancing app that Jason Howell was all gaga over. As for right tones I noticed no difference. It did enhance headset volume.... Hope that helps
  4. #4
    tirith's Avatar
    Resident Linux Fiend
    Posts
    ROM
    Stock Touchwiz LJC 4.1.1
    Default
    menu - settings - sounds - volume. Disable use default for notifications. Set notifications to minimum. Ensure vibrate is allowed.
    Sent using my MoPho-King photon
