Results 1 to 3 of 3
    drummer7's Avatar
    Posts
    Global Posts
    116 Global Posts
    ROM
    Oxygen/Netarchy
    Default help :/
    hey guys. gotta bit of a problem. My messenger was force closing so I rebooted my phone and not it's stuck on the android bootscreen all day. I was wondering what to do. Is there any way to salvage my phone with out having to lose all my data?
    I have dooderbutt Rom btw
    thanks for the help
  2. #2
    Skunkape60's Avatar
    Retired Ambassador
    Posts
    Default
    I'm guessing you have tried pulling the battery?
    ____________________
    Just Flash It !!!
    http://forums.androidcentral.com/signaturepics/sigpic70132_2.gif
    drummer7's Avatar
    Posts
    Global Posts
    116 Global Posts
    ROM
    Oxygen/Netarchy
    Default Re: help :/
    yeah did that all day. All wiped cache which didn't work. I ended up wiping all data and re flashing the rom. it solved the problem.
