Results 1 to 16 of 16
    Default Rapid Battery Drain
    I have been noticing that my phone's battery gets drain really fast with using gps or streaming music When using either of them the battery goes from 100% to 0% in 2-3 hours. I installed gsam battery monitor and it showed that andriod system is using 32% of the battery dont know if its normal or not.
    Phone is using custom slim 4.2 ..
  2. #2
    Default
    Normal for our nexus s 4g. I just bought the seido 1750 mah, I was reluctant to get it and I really didn't want to get the 3500 mah battery because of its thickness. Price difference is 5 bucks between both.
    Now I'm able to go through out the day without a charge....
    Sent from my Nexus S 4G using Tapatalk 2
    Default Re: Rapid Battery Drain
    You know I guess this rapid battery drain doesn't make sense, getting a higher battery will only temporarily solve the problem .Seifeo is 250 mah more then the stock, so how many hours are you getting with regular use.
  4. #4
    Its quiet common that the battery drains when you stream music. But when you install the app called 'Battery Booster', the life time of your battery can be saved by 50 - 60%.
  5. #5
    I installed CyanogenMod 9 and have seen some gain in battery life by turning on "deep idle" (a setting in CM9).
  6. #6
    Try my guide How to Improve Battery life -Tips and Tricks
    try tip 2,5,8,12
    I think my main concern is the phone temp its always atleast 100 . Not sure if this is normal or not. Used to have htc evo before and that never ran so hot. Guess different manufactures does things differently ..
  8. #8
    Cyanogenmod 9 with deep idel turned on has made an improvement for me.
  9. #9
    This is nuts. For the past few weeks it's been draining crazy fast. This morning, for instance. On my drive to work - 30 MINUTES! - it lost 20%...from 91% down to 71%.
    I'm so fed up with this phone.
  10. #10
    Quote Originally Posted by j_grouchy View Post
    That was posted at 8:18 am. Not even TWO HOURS ago...and now it's down to 27%.
    Seriously. This is getting ridiculous.
  11. #11
    I had the SAME problem. I installed CyanogenMod9 and turned on deep idle and it's improved a lot. Just try it.
  12. #12
    Quote Originally Posted by 6tr6tr View Post
    I'm not rooted and I'm not really clear on the effects of or the process of rooting and/or flashing. At this point I just feel like it's too late...
  13. #13
    The nice thing about CM9 is that you can turn rooting off (which I have done). It's just a setting in the Settings app. So you root the phone to install CM9 and then once you boot up, just go into:
    Settings -> Developer Options -> Root access (Disabled)
  14. #14
    But, in getting to that point, aren't you basically wiping everything off your phone and starting fresh? While there's probably something cathartic about it, it seems like it would be kind of a pita...if you get my drift.
  15. #15
    Mellimel22's Avatar
    Posts
    Global Posts
    2,165 Global Posts
    ROM
    Muzzyz 4.2.1 build
    Default
    No it basically hides the superuser access but it still shows that the boot loader is unlocked and those battery saving tips worked
    Sent from my Nexus S 4g rockin jellybean using Tapatalk 2
    Attached Thumbnails Attached Thumbnails Rapid Battery Drain-uploadfromtaptalk1345917792693.jpg
  16. #16
    Yes, you do have to clear everything off the phone but:
    1. You can back up your call logs and a lot of the other local info before rooting
    2. Most stuff is stored "in the cloud" and thus can be restored automatically
