Bob61
When i had that problem i cleared problem by resetting my Sync.
Sent from my DROID RAZR HD using Tapatalk 2
I own a 2011 Fusion. I can tell you right now. If your blue-tooth audio connection stops working (and usually sync stops accepting voice commands), give up all other efforts. You have no choice but to live with it OR disconnect your (car) battery for a few minutes, then reconnect it. Every time this happens, I promise myself I will never, ever gain buy another Ford. It's been a problem for years, and they should fix it, and then offer a recall (to apply the fix) for all the affected vehicles.
