Results 1 to 3 of 3
Like Tree1Likes
  • 2 Post By cpaight
    Default Sprint Nexus S 4G Help
    Hello everyone. I recently purchased a Sprint Nexus S 4G for a backup phone so I went ahead and activated it. Its a 16gig and I downloaded some apps on it. It shows internal storage as being almost full at not even 800MB of apps installed and 189 Mb available. Then under that, it shows 13.5 GB available in USB storage. What is this? Can anyone assist me with this. Is the USB storage not available to me for some reason? Thanks
    Sent from my HTCONE using AC Forums mobile app
  2. #2
    cpaight's Avatar
    Posts
    Global Posts
    698 Global Posts
    Default Re: Sprint Nexus S 4G Help
    If I remember correctly (it's been a year and a half since I had that phone) if you go into settings/apps you'll get a list of all your installed apps and next to them will be a button that says "move to usb"....some apps cannot be moved, but most that you download from the Play Store can.
    msndrstood and Hvacmanjc like this.
  3. #3
    cptsales's Avatar
    Posts
    Global Posts
    8 Global Posts
    I would suggest the app Clean Master, allows you to move apps to the SD card, and also to disable some of the stock Android programs. Allows me to still use my NS4G to this day!
  1. Moving from iPhone 5 to Android device, Help. i cant decide
    By aliadonis in forum General Help and How To
    Last Post: 05-16-2014, 07:20 PM
  2. Need help on different things....
    By GGearX in forum Samsung Galaxy S5
    Last Post: 05-15-2014, 12:29 AM
  3. Replies: 1
    Last Post: 05-14-2014, 09:16 PM
  4. Nexus 10 not pairing with plantronics backbeat go 2
    By Joe Loyzaga in forum Google Nexus 10 Tablet
    Last Post: 05-14-2014, 07:28 PM
  5. G note3 fm transmitter help
    By Davie Brown in forum Samsung Galaxy Note 3
    Last Post: 05-14-2014, 06:56 PM
