Results 1 to 13 of 13
    Default Nexus initial charge
    new to the forums i understood that your not supposed to turn on the phone for the first time until fully charged. but with no notification led how does it tell you? how do you know when it is fully charged?
  2. #2
    Default
    I don't think it really matters, plug it in turn it on and don't start using the phone till its at 94-95%. Thats as high as it will go.
  3. #3
    dunivan's Avatar
    Posts
    Global Posts
    222 Global Posts
    ROM
    Stock
    Default
    mine was around 40% charged, similarly my cr48 was at 42% charge.
    Nexus S 4G Launch Day Owner
  4. #4
    Default
    Quote Originally Posted by dunivan View Post
    *drool*, we'll we know your a google fanboy :-p.
    Default
    so do i turn the phone on? how do you know when its fully charged when the is phone off & charging?
  6. #6
    AndroidOne's Avatar
    Posts
    ROM
    Stock Android 4.0.4
    Default
    Quote Originally Posted by idontknoww View Post
    You can actually use the phone while it charges, there is no problem. Only thing if you do, it will charge at a slower pace than if you leave it off or idle.
  7. #7
    jtexans's Avatar
    Posts
    Global Posts
    190 Global Posts
    Default
    battery widget.
    btw, mine wouldn't charge over 94%...
  8. #8
    Nick1472's Avatar
    Posts
    Global Posts
    77 Global Posts
    Default
    Quote Originally Posted by jtexans View Post
    battery widget.
    Same here, usually 95%, but think that is normal so the battery is not overcharged. Here is an article I found that explains it:
    Unnamed Applications
    Apps in the Android Market: Sports Calendar
    www.unnamedapps.com
    @unnamedapps
  9. #9
    Beezzy's Avatar
    Posts
    Global Posts
    846 Global Posts
    Default
    The highest I've gotten mine was 96%. I've removed the battery and it shows something on the Nexus S, something like 1440mah and the battery is 1500mah so that might have to be why the Nexus S is only changing to ~95%
    Sent from my Nexus S 4G using Tapatalk
  10. #10
    KoukiFC3S's Avatar
    Android Connaisseur
    Posts
    Global Posts
    2,402 Global Posts
    Default
    When its off and charging a big battery icon shows on the screen.
  11. #11
    vertigosrs's Avatar
    Posts
    Global Posts
    111 Global Posts
    ROM
    Miui/Pete's Kernel
    Default
    First charge went to 95%
    Second went to 97%.
    Phone - Nexus S 4G
    Rom - Matr1x Rom
    Kernel - Latest CFS Version Of Matr1x
  12. #12
    AndroidOne's Avatar
    Posts
    ROM
    Stock Android 4.0.4
    Default
    As it has been said many times before, the charging circuit will limit the charge short of full to protect the battery. Don't loose anymore sleep over this.
  13. #13
    Default
    Thanks for the article link. I have just removed my battery meter. No sense in obsessing over it.
