Nexus S Facebook, LED, microSD, Email, Text, & Camera Workarounds
Zorachus
337
15
18
Re: Nexus S Facebook, LED, microSD, Email, Text, & Camera Workaro
I installed Syncmypix, and got most of the pics to show up in contacts. But what about my own pic from Facebook ? I have my dog as my pics on FB, and want that on my phone too, mainly for texting, I like to see that pic as me while texting, when I am texting people with no pic it gets confusing seeing both greyed out boxes.
milominderbinde
2,163
1,179
Galaxy Nexus Workarounds
The Galaxy Nexus is a great phone offering a "Pure Android Experience." That purity brings differences a typical Android owner may not have seen before. Here are workarounds for Facebook Sync, LED Blink Rate, microSD, Speed Dial, Smart Dial, Messaging Enter Key, Browser Zoom, FM Radio, Visual Voicemail Photos, etc. Some also "Root" and replace everything with a different "ROM."
Facebook Sync: Is "...removed...from all future 'googlephones'..." The Galaxy Nexus doesn't sync Facebook profile photos, status, messages, phones, events, birthdays, or notifications. Calls don't pop-up with new profile photos.
• Workaround: Friendcaster (free, $5: no ads) or Haxsync for ICS add many sync features back in.
Notification LED Slow Blink Rate: The Galaxy Nexus Notification LED blinks slowly, about once every 10 seconds. To be sure it is not blinking, look at it for a full 10 seconds.
• Workaround: LightFlow Lite let's you customize blink rates, vibrations, sounds, and repeats.
microSD: microSD cards store movies, photos and music, backup texts, alarms, settings, and Nandroid backups. A microSD slot adds 2% to the volume. microSD cards are under $50 for 32GB.
• Workaround: Use free "Cloud Storage" like Dropbox (extra for free), Google Music, Google Docs, etc.
Low speaker/headphone volumes: Some feel that the maximum volumes are too low.
• Workaround: Volume+ Sound Boost (dev website) let's you increase the volume.
Battery Life: The Nexus is a fire-breathing dragon with a big screen, LTE, and six other radios. That takes a lot of power.
• Workaround: Consider an extended battery and see the Battery Life Tips.
Messaging: The Nexus messaging is missing the Return Key.
• Workaround: HandCent or ChompSMS add many texting features.
Visual Voicemail: shows the caller's photo. A slider bar lets you play a certain portion as you would an MP3.
• Workaround: Youmail will show the caller's photo.
Speed Dial: The Nexus Lacks Speed Dial to assign contacts to numbers 1 to 9. Long-press 2 for Voice mail, etc.
• Workaround 1: Get an app like Go Contacts or TouchPal Dialer for Speed Dial.
• Workaround 2: Create Dialer Shortcuts on a home screen for each number.
Smart Dial: The Nexus lacks smart dial. "T9" smart dial lets you type a name such as: 2 for B, 7 for R to see names beginning "Br".
• Workaround: Get an app like Go Contacts or TouchPal Dialer.
Contact Search: The Nexus lets you search names but not city, street, notes, etc. such as, "Who is on Baker street?"
• Workaround: Go Contacts & TouchPal Dialer search names, city, street, etc.
Clock: The Galaxy Nexus Clock does not include a Timer, Stopwatch, World Clock, etc.
• Workaround: Consider one of these full-featured Clocks.
Browser: If you pinch to zoom, the text does not always word-wrap.
• Workaround: Browsers like Dolphin or Opera word-wrap. The manual reflow trick can help too.
5 Home Screen Limit: ICS does not allow Homescreens to be added.
• Workaround: Get a launcher like LauncherPro, ADWLauncher or Nova Launcher to add or remove home screens.
Keyboard Text Predictions: The ICS keyboard is good but some have problems with the text predictions or want more features.
• Workaround: Consider SwiftKey, Swype, or other Keyboards.
Search Window on every Home Screen: The top 1/5 of each screen is now a search bar.
• Workaround 1: LauncherPro, ADWLauncher or Nova Launcher let you use a 1x1 Search icon just on the pages you like.
• Workaround 2: Settings > Manage apps > Google Search > Disable. Download Google Search from the market and use it instead.
FM Radio: The Nexus lacks an FM Radio.
• Workaround: Consider TuneIn (Pro) for local AM/FM stations or Pandora, Slacker, and iheartradio.
ICS Tips & Tricks
These tips are specifically for Android 4, Ice Cream Sandwich. 500 general Android tips are in the Getting Started guide.
Basics
attachment.php
Home: To see your home screens with your apps and widgets.
attachment.php
Menu (Technically "Action Overflow"): Tap to see Menu options.
attachment.php
Settings: The fast way to Settings is to swipe Notifications bar down and taps the settings icon.
attachment.php
Back: The Back button moves you back.
attachment.php
Recent Apps: Swipe up or down to view open apps. Swipe left or right to close an app.
attachment.php
All Apps: Tap to see your all of your apps and widgets.
Home screens
Add an App: To add an app to a homescreen - Tap
attachment.php
All Apps > Drag the app where you want it..
Add a Widget: Place a widget On a home screen - Tap
attachment.php
All Apps >Widgets > Drag the widget where you want it.
Folders: Drag and drop one icon on top of another to start a folder.
Settings Shortcuts: To place a settings shortcut on a home screen, tap My Apps > Widgets > Settings shortcut
Show more icons: Get a launcher like LauncherPro, ADWLauncher or Nova Launcher.
Settings
Turn LTE Off: To save a lot of battery, go to
attachment.php
Settings > More > Mobile networks > Network Mode> CDMA.
Animation Speed: To change speed, go to
attachment.php
Settings > Developer Options > Window / Transission animation scale
Apps
Download a New App: Tap
attachment.php
All Apps > Market, and find a new app.
Remove Bloatware without Rooting: Disable apps you can't remove in
attachment.php
Settings > Apps > {app} > Disable.
Uninstall an App: Fast way is to tap
attachment.php
All Apps and drag the app icon to the word Uninstall at the top.
Sync
Sync Photos with Picasa: Go to Settings > Accounts & sync > Google > Sync Picasa
Camera/Video
Take a Photo While Video Recording: Just tap the screen while recording a video.
Take a Photo From Lockscreen: Drag ring to Camera icon to instantly open camera.
Take a Screenshot: Press Power and Volume down at the same time.
Notifications/Unlock
Unlock Options: Go to
attachment.php
Settings. Security > Screen lock to select None, Slide, Face Unlock, Pattern, etc.
Facial Recognition: You can have multiple reference photos with a beard or makeup and without or for 2 people.
Clear a Notification: Fast way is to swipe down Notification and swipe left or right on the notification to clear.
Immediate Response: If you use Slide to Unlock, swipe down on the Notification bar to respond directly.
Phone
Text Reply To A Call: When a call comes in drag up and choose which message to use.
Phone Settings: In the Phone app, tap
attachment.php
Action Overflow > Settings.
Clock
Blue Clock: Open the ICS Clock app, long-press anywhere to dim and turn the display blue.
Set an Alarm: The fast way is to tap your clock widget and you are there!
Browser
Browser Quick Controls: Browser
attachment.php
Action Overflow > Settings > Labs > Quick Controls. In a website, press on side of screen.
Tabs: Tabs are browser windows. Tap Settings to open a tab. Swipe up/down to view. Swipe left/right to close.
Browser History: As in Gingerbread, long-press
attachment.php
Back in the ICS browser.
Save a webpage: In the browser, tap
attachment.php
Action Overflow > Save for offline reading.
Other
Google Wallet: Get Google Wallet on your Galaxy Nexus with no hackery
Thanks to terpitude71, mclarryjr, Cyber Warrior, and so many others for help in preparing this.
Resources
Nexus S Workarounds
ICS Highlights
Android Ice Cream Sandwich: 11 awesome tips and tricks
Android 4.0 Ice Cream Sandwich Tips and Tricks [VIDEO]
Complete Guide to the Galaxy Nexus 4G LTE [Verizon]
Ice Cream Sandwich tips & tricks | The Verge Forums
Ice Cream Sandwich: Hints, Tips and Tricks
A User's Guide to Android Ice Cream Sandwich
Ice Cream Sandwich Google Apps tip: long press any icon for its ...
Android 4.0 Ice Cream Sandwich: 8 Essential Tips and Tricks
Tips and tricks for your new Galaxy Nexus
Reactions: giograves
Paul627g
AC Moderator All-Star
Moderator
Nov 25, 2010
15,963
2,752
Reactions: cabrone
giograves
295
13
Is the Nexus S really limited to 512 MB "Internal"? How does that affect the fatter ICS update?
Speaking of which, does ICS improve anything in the OP?
jeffrok
577
21
In the original post of the thread, the OP discusses the Nexus S' 512MB of Ram,and advises people to move apps to SD if this is an issue..
I don't see how the RAM and internal flash memory have anything to do with one another, and besides, in addition to the 512MB RAM and 16GB of onboard flash memory, isn't there another dedicated 1GB onboard for OS?
that party of his post just doesn't seem right.
