Results 1 to 25 of 25
    Default EVO users that switched to Nexus 4G
    I just got my Nexus S Monday and so far I like it a lot. I left the EVO but it was only after weeks of back and forth trips to best buy. After hearing all of the bad things about the nexus I decided to give it a try. After two days i'm really starting to love this phone. I have not had any of the issue reported in some of the forums. Yes, the 3G and WiFi signals do seem to be weaker than on the EVO but I have not had any dropped calls or wifi connection problems. I think the confusion is that the EVO and other phones has six bars and the Nexus has 4 bars. Naturally, the scale it uses to calculate the signal is going to appear be weaker.
    Here is my review so far. The Nexus is a sexier phone on the outside and it feels really good in my hands. It seems faster because it does not have all of the bloat from Sprint. It does not have an external SD card but is has an extra 16GB of storage internal. There is no flashing indicator lights even though they appear to be installed on the device but not activated. Hopefully a software update in the future will turn these on. The biggest problem that I have is the AMOLED screen which is not as clear and crisp as the EVO even though every body raves about the Samsung AMOLED i'm not impressed with it. Other than that I love this phone.
    Please let me here from other users that switched from the EVO and tell me how your compare it to the Nexus.
  2. #2
    Default
    Quote Originally Posted by droid_4_life View Post
    They call me K.P. the dream crusher and I've come to do my job! (J/K)!!!!! You're either confusing the light sensor, the proximity sensor, or the FFC, all of which are on the front of the phone, as an LED indicator. Bottom line is, no matter how much software gets pushed, theres no LED to activate. Sorry.
  3. #3
    s14tat's Avatar
    Posts
    ROM
    AOKP ICS build 38
    Default
    I don't have an evo but i have spent enough time with one esp ones that are rooted and running cm7. Don't be fooled by the specs even though they are identical. The Nexus S is a much faster phone no matter what you do to the evo. The hummingbird is far superior to the snapdragon. The evo can't even run live wallpaper and scroll smoothly even over clocked to 1.2 ghz and running cm7 with sense ui being completely gone. A nexus S or any other galaxy S variant to run that no problem with no studder. Nexus S or any other galaxy S has the best gpu on any single core phone bar non. I'm not running a nexus but i'm running a galaxy S with voodoo lag fix which turns samsungs filing system to what the nexus S runs and my friend with the evo is doing everything he can to match my phones speed and smoothness. ( He can't, his hardware is too weak )
    I think you might have a defective screen on your nexus S or your brightness is not turned up to max. Its kinda pointless to turn the brightness all the way up with the evo because the blacks starts looking washed out and gray while the S Amoled screen the blacks are so black that you can't tell where the borders of the screens are even on max brightness. The colors just pop out.
    The camera is far superior on the nexus S also even though it has a higher mega pixel count on the evo. The only thing that the Evo has is the built in fm radio tuner, and the gps locks in faster. Everything else is a step or 2 down.
  4. #4
    Default
    After about a week, go back to the EVO and tell me if the evo's screen is better. There isn't a phone available on any carrier that I would choose over my Nexus S. I almost made the mistake of taking my Nexus S back for the EVO. Glad I changed my mind.
  5. #5
    jnl813's Avatar
    Posts
    ROM
    Viper Rom ICS Android 4.0
    Default
    Quote Originally Posted by KSmithInNY View Post
    Lol software update might fix this lol nope sorry
    Sent from my Sexy Nexus 4G
  6. #6
    Linkchomp's Avatar
    Droid Monster
    Posts
    Global Posts
    748 Global Posts
    Default
    It doesn't matter to me about the LED flashing thing. iirc, there's a ROM for it. I got my new Nexus S purchased off contract. I just gotta activate it and dump m Evo.
    Live long, Rock hard
    Best in the World
  7. #7
    Default
    Quote Originally Posted by jesse813 View Post
    Lol I did my job!
  8. #8
    Default
    Quote Originally Posted by The Miz View Post
    There's no ROM that can fix a lack of hardware. The best thing you can hope for is noled (free in the market) in combination with BLN control which requires a custom recovery to flash a compatible kernel. Still with both of those, they aren't a substitute for an LED, just the best option we have.
  9. #9
    Linkchomp's Avatar
    Droid Monster
    Posts
    Global Posts
    748 Global Posts
    Default
    ...so was Google drunk or something when they made the phone and didn't include it? Or were they savng hardware specs?
    Best in the World
  10. #10
    Default
    Lol well technically Samsung made the phone, google only approved it to be a developer flagship device. That said, there's no excuse for El Goog, sprint, or Samsung for releasing a device post 2009 without a notification LED. Had this hit my hand in development phase I would have been squawking about the LED (or lack of).
    With that said, I bought the phone knowing it didn't have an LED indicator. I kept it 30 days. So if I had to blame anyone for it I'd blame myself because I chose to keep the device despite this flaw.
  11. #11
    ragnarokx's Avatar
    Posts
    Global Posts
    8,674 Global Posts
    ROM
    N4: MMuzzy, N7: SlimBean
    Default
    Android phones that have LEDs are pretty hit-and-miss functionality-wise anyway. Hopefully when the next Nexus is released, it will have an LED and full support from Google to make it work.
  12. Thread Author  Thread Author    #12
    Default
    Thanks for clearing that up. I actually thought they installed them but did not activate them.I did not think of the options that you mentioned.
  13. Thread Author  Thread Author    #13
    Default
    Quote Originally Posted by s14tat View Post
    Thanks for your comment!!
  14. Thread Author  Thread Author    #14
    Default
    Quote Originally Posted by dwaynewilliams View Post
    I will try that. I actually have not turned on my EVO since i got the Nexus. Maybe I will see the difference.
  15. #15
    NOMster's Avatar
    Posts
    Global Posts
    224 Global Posts
    ROM
    depends on the time
    Default
    I came from an evo and never looked back. If Sprint had released the nexus one I would have gotten it instead of an evo in the first place.
  16. #16
    Linkchomp's Avatar
    Droid Monster
    Posts
    Global Posts
    748 Global Posts
    Default
    I keep thinking Google was in on it as well lol. But it's not too big of a dealbreaker for me considering I can just as easily go to my laptop and check my email(without a notification).
    The fact A. the screen looks better B. it's fast C. updates directly from Google and D. They actually have a case in the color I want for it is what kept me with it.
    Quote Originally Posted by NOMster View Post
    Ditto. I just powered on my Nexus, haven't activated it yet though. It's already looking to be better than the Evo and it is FAST. It feels so good to have vanilla without all the toppings and flavoring.
    Best in the World
  17. #17
    Default
    Even though I have newer phones, I was using the evo when I decided to get this phone. My evo, a refurbished, started developing a brighter white patch on white screens that was annoying me. I traded in the htc for the ns4g so they'd take 150 off the full price.
    I was kinda meh in the beginning with the performance of internet speeds. The longer I kept this one, the more it grew on me. One of the things that is a reason why I didn't return it was I'd be getting updates and bug fixes much sooner than the other phones (or so they say). Does the phone **** me off sometimes? Yes. Do I regret or hate it? No. This phone isn't for everyone. Those of you who like the vanilla experience will probably like the phone.
  18. #18
    dj2big's Avatar
    Posts
    Global Posts
    559 Global Posts
    Default
    I miss my EVO this Nexus has way to many glitches
    Juan Too Big Perez
    DJ2BIG.COM
  19. #19
    Default
    Quote Originally Posted by dj2big View Post
    What glitches are you experiencing?
  20. #20
    Default
    I bought the NS4G on launch day and gave my Evo to my girlfriend to replace her Intercept (you want to talk about glitchey?). I've rooted the NS4G and then unrooted it when I realised that when I rooted my Evo it was to remove Sense and not for wifi tether or anything else. Now if Google/Sprint/Samsung could just get an update together to fix the radio issues I wouldn't have one complaint.
  21. #21
    Default
    You gotta remember it just came out, of course there will be some glitches. Although, I only have a few glitches that will (should) be addressed soon, so I dunno how many glitches you're seeing. Maybe a defective phone. But these kind of radio issues are bound to happen eventually when the phone is initially released. Didn't it take 3 months before the EVO wasn't crap? Plus, being a Google phone, updates won't have to be rerouted through a different skinning to work and we'll just get it straight and fast.
    Anyway, I love this phone. It's fast, the screen is GREAT, it doesn't feel cheap, I like the curved design, and it beats the hell outta my HTC Hero. Although that wasn't a bad phone once you get CM6 and then later CM7 on it. Don't regret the purchase at all.
    EDIT: Oh, forgot to mention, the lack of an LED indicator doesn't really bother me. It's not that hard to hit the power button and look for the icon at the top. I check the time that way sometimes anyway, so I don't really see that huge a deal.
  22. #22
    Default
    todays the day. my mother, has been itching to try out a smartphone. so, last week, we went down to the sprint store, looked at the Epic, looked at the Nexus. she really didn't like anything coming out. she however, did really like my evo, which at the time was rooted and was running a sense 2.1 rom.
    to make a long story short, i get a nexus s for free, and she gets to try out the life of android. win win!
  23. #23
    sedracer's Avatar
    Posts
    Global Posts
    18 Global Posts
    Default
    i'll be trading the evo for the nexus on the 24th when the 3d comes out because the nexus price is dropping lol, i'll be able to trade the evo straight across with my upgrade for the nexus. the evo 3d is probably the ugliest phone i've seen htc produce in quite some time.
  24. #24
    igotsanevo4g's Avatar
    Retired Moderator
    Posts
    Global Posts
    3,549 Global Posts
    ROM
    Ice Cream Sandwich
    Default
    This thing is kicking the heck out of my old evo on cm7 and I'm actually getting BETTER signal and data speeds.
    The evo is fast, but this is FASTER.
    Sent from my Nexus S 4G using Tapatalk
    Some say the glass is half empty. Some say its half full. I say, "Are you going to drink that?"
  25. #25
    sedracer's Avatar
    Posts
    Global Posts
    18 Global Posts
    Default Re: EVO users that switched to Nexus 4G
    well i posted this earlier in the week, had my nexus a couple days now and can say i haven't missed the evo a bit.
    better screen, more responsive, better battery life, and even tho its lighter it feels more solid, and the murdered out front when the screen is off is so so beautiful. i rooted the evo on day one and i don't even have a desire to root this.
    not to mention i'm not having any service issues, its the same if not better service than my evo did. wifi signal strength is a bit suspect but built wireless-n support is much appreciated.
