I just switched from my NS4G and want to setup my Photon the same way but can't use google voice.
I would have a group setup called gv and when anyone in that group was called it useid my google #.
or I could use the app. vopice plus and switch what number I dialed from.
that worked great to be able to switch from my cell and google # (when I wanted to have my google # and not my cell given out)
but I did know that you had to use the google voice app 0.4.2.30 the only version at app store now is the new version .32 and it will NOT let you do it,
has anyone been able to figure this out???
whit th new version you have to use either your google or cell number, but cannot use both on command.
