Results 1 to 25 of 41
- 08-12-2011, 07:18 PM
Thread Author #1
Voice Call Audio Resolution
Has any one fixed the issue where you have no audio on voice calls? It seems to come from nowhere randomly. Any one got a fix?
Sent from my MB855 using Tapatalk - 08-12-2011, 07:26 PM
Thread Author #2
Trying the sim card trick now.
Sent from my MB855 using Tapatalk - 08-12-2011, 07:49 PM #3
- 08-12-2011, 08:49 PM #4
- 08-13-2011, 06:21 AM #5
Re: Voice Call Audio Resolution
Remove the sim card from the phone. It seems to help most people (including me) from having this issue. ALSO...GV, if uninstalled, you still have to goto your GV settings on google's site and disable your phone from GV. Otherwise the phone still tries to route your calls/voicemail through it causing alot of headaches.
I need more coffee...... - 08-13-2011, 08:40 AM #6
the sim card trick Does Not work. Had to restart a few mins ago.
- 08-13-2011, 12:27 PM #7
- 08-13-2011, 12:54 PM #8
- 08-13-2011, 01:01 PM #9
Wow. Was hoping that would be a universal fix!! It's been five days now without that problem since I removed mine. But I only hadit happen a handfull of times and I never had to reboot. I just had to hang up and call back.
I'm wondering if it really has more to do with GV? I did both pretty much at the same time and GV loves to take over your phone. Since the sim stores phone info and GV changes how the phone routes and receives calls, if it's more of a combination of the two? - 08-13-2011, 01:48 PM #10
- 08-13-2011, 02:02 PM #11
- 08-13-2011, 05:04 PM
Thread Author #12
Seems to be working so far for me.
Sent from my MB855 using Tapatalk - 08-13-2011, 07:33 PM #13
Sprint rep said an update should come out soon and fix this.
Also, it's on a case by case basis, so hanging up and redialing might work. - 08-13-2011, 09:00 PM #14
- 08-14-2011, 06:37 AM #15
I don't get a lot of phone calls. It's happened on 4 of the 6 calls I've received. I need to reboot and call back.
Have folks had success trading in the phone for a new unit?
I need to decide whether to do that or to ignore it or to try a frankenpre. - 08-14-2011, 07:21 AM #16
A few things I have read about what causes the problem/ possible solutions
1) GV
2) previous phone still has cellular radio on
3) removal of sim card
That being said I have not had this problem yet <shrug> - 08-14-2011, 08:09 AM #17
The best way to fix this issue currently is to switch to a different phone. My EVO 4G hasn't locked up or had a silent call since I switched back
- 08-14-2011, 08:13 AM #18
- 08-14-2011, 08:15 AM #19
- 08-14-2011, 10:09 AM #20
I think it's something that happens to the phone eventually, if it's up long enough without a reboot. Because I get very few phone calls on it, it has usually been up for a long time when I get one. Then I reboot it due to the "no sound" issue.
One of the calls was a wrong number, by the way. No harm in failing to have answered it.
- 08-14-2011, 11:35 AM #21
Yesterday has been good. 4-5 calls and they all worked.
- 08-15-2011, 01:36 AM #22
I have replaced the phone twice and each one has exhibited this problem. The second was worse than the first, and this third one may trump them both. The EVO 3D and its horrible battery is looking like an amazing piece of technology compared to this poor excuse for a phone. I would not have accepted this in 2001, let alone 2011.
- 08-15-2011, 06:06 AM #23
- 08-15-2011, 10:52 AM #24
I haven't had this problem. But some people who have manually installed the leaked maintenance release have reported that it resolved the problem. So you could try that. You'll need to root first, unless you want to wait for Sprint's official OTA update.
Samsung Galaxy S3 (Rooted) - 08-15-2011, 11:02 AM #25
Actually, one of the latest reports from XDA was that MR5 did not repair the issue.
Reply
