1. Moegitto's Avatar
    I was wondering if anybody knew the solution to this? This kinda sucks because I like to put my phone by my pillow and use it as an alarm. I have all my sounds turned up, but the sounds is pretty pathetic.
    10-28-2011 12:34 PM
  2. zooradley's Avatar
    I had the same issue... volume was up, wasn't using the 'increasing volume' feature. Couldn't figure it out the problem. After a couple close calls (oversleeping), I downloaded Alarm Clock Plus (by CVP) and it's been great.
    10-28-2011 01:41 PM
  3. Gator352's Avatar
    I love moto's hardware but they need to universally file the software designers. It's obvious they need more training in software development.
    The software in my sons leapfrog pc thingy is more advanced and works better than any software made by moto on my photon. Don't get me wrong, the mopho is awsome, just not the software.
    10-28-2011 01:54 PM
  4. KahneFan's Avatar
    Alarm Droid is GREAT! I use it instead of the default application.
    10-28-2011 02:51 PM
  5. kmcochran's Avatar
    I don't have any problems with the stock alarm volume. I did transfer the "dulcimer" ring tone from my Pre to the Photon to use that as my alarm sound. Maybe you just need to change what tone it's using.
    10-28-2011 03:56 PM
  6. Puzzlegal's Avatar
    The sound is about twice as loud if the back isn't muffled against something soft like your pillow. Try putting it next to the bed on a flat surface.
    10-28-2011 10:53 PM
  7. bkhoste's Avatar
    Check when you set the alarm that the "Use increasing volume" is not checked, mine was low until I noticed that and unchecked it.
    10-30-2011 08:22 PM
  8. frozndevl's Avatar
    I have no issues with my alarm volume. I transferred "light" from my Evo and have my MoPho sitting on my bedside table with the escalating volume.
    11-03-2011 01:10 PM
  9. rbeavers's Avatar
    Years ago, with my 1st phone. I took my ring tones, allarms and notifications
    and ran them though Audition.
    Boosted them 10db added some compression,
    my Dr Who ring tone scares the heck out of people.
    11-04-2011 05:08 AM
