Results 1 to 9 of 9
    strawhatnito0890's Avatar
    Posts
    ROM
    JOKER'S CM9 ON PHOTON
    Default help wit wifi hotspot
    Omg i cant get my moto photon to connect to my ps3 please help
    NITO KUSH
  2. #2
    Default Re: help wit wifi hotspot
    Quote Originally Posted by strawhat nito0890 View Post
    I am just assuming here, but.....
    Did you call Sprint to activate the hot spot wifi feature?
    I believe you can also do it on your online Sprint account or at least check it's status.
    Hope that may help u
    •» Tip: Never rush to download any APP "Updates", read the feedback for a few days so that you can see if other people are having issues with it and/or changes to permissions or other you may not want! Always use a Back Up APP!
    •» Free DropBox! Back up to & Sync your Phone to your Computer Free! Always have your stuff when you need it with @ Dropbox . 2GB Plus account is Free! Plus earn up to 500 Mb's for each referral! Up to 32GB Free! http://db.tt/szmjeyX
  3. #3
    Default
    You may need a rom with hotspot hack to use sprint hotspots w/o paying $30 per month. If you are rooted, you can use wifi tether (search Google for android wifi tether) it downloads a .apk from a Google code website
    Sent from my Galaxy S II epic 4g touch. 4.0.3 FC05 ICS
    Posts
    ROM
    Default
    Yea I'm just goin to unlock my bootloader so i can try out roms on it
    K.U.S.H 305 MB855
    NITO KUSH
  5. #5
    Default
    With the help of this forum (for rooting) and wifi tether i was able to connect my pc and if i place my mopho near the window i can get 4g speed also.
  6. #6
    Default
    use an app called foxfi
    Sent from my Motorola Electrify using Android Central Forums
  7. #7
    Foxfi Works GREAT!!!!!!
  8. #8
    Default
    Ditto foxfi. No root needed! Google it.
    Sent from the baddest MoPho on the planet!
  9. #9
    tirith's Avatar
    Resident Linux Fiend
    Posts
    ROM
    Stock Touchwiz LJC 4.1.1
    Default
    Or just go to foxfi (dot) com
    Sent using my MoPho-King photon
