Results 1 to 9 of 9
    Default Photon wont charge or power up - Dead
    Did a search but couldn't find anything.
    Photon 4g is dead. Been running errands all afternoon, then this evening I went to check my phone and it was powered off. Can't get it to charge, power up or anything.
    Tried pwr button with volume up, down, and both, even tried camera button. All held for varying lengths up to 35 seconds.
    Battery pulled, sim pulled, SD card pulled,,, for 30 minutes, reinstalled and nothing. With or without them being installed.
    I get a white light for about 1-2 seconds when I plug it into the computer. (computer does not recognize anything is plugged in)
    Found another forum where someone used usb cable with stripped end and put red wire to + and black to negative for 15-20 minutes(one user reported success) but nothing happened for me.
    Have new batteries on order. Phone was rooted 4 months ago and was working great! No new apps or changes were installed in the past few days.
    Purchased from radio shack. Purchased 9/15/2011
    Thoughts? Sprint store has never been much help cause I didn't buy it from them.
  2. #2
    Default Re: Photon wont charge or power up - Dead
    My charger and cord crapped out on me a year ago. Have you tried different cords /chargers? You can take it to radioshack to troubleshoot the problem. (And they usually have good batteries at a cheaper price ) but that was two years since I've worked for them. Not sure now.
    Yea, I have tried different chargers and cables. Charge tried from car, home and PC.
    When I charge from PC, I can get a white led with one of the cables I tried, but nothing else happens.
    I spilled tea yesterday before starting my errands, but I'm pretty sure it didn't hit the phone. Where can I check to see if I have liquid damage? If I did spill on the phone I will bite the bullet and pay for a new phone, but if it is as I suspect, no water damage, then I will send it off to Motorola.
    I have no colored stickers on the battery or under the battery,,, just black and white text.
    Thanks,
  4. #4
    tirith's Avatar
    Resident Linux Fiend
    Posts
    ROM
    Stock Touchwiz LJC 4.1.1
    Default
    I know when powered down completely dead, it takes forever to get enough charge to reboot....
    The water damage strip is inside the phone...
    Sent using my MoPho-King photon
  5. #5
    Did you install the latest software update? The reason I ask is that I participated in the SOAK test and with the latest update, it bricked my phone. I had to get a new one.
    One thing to try is to leave your phone plugged in for at least 30 minutes via the wall outlet and see if it will come on then. Someone suggested that to me and my phone did come back on (and it was at 90% before it went dead) and then when it got to 100% I unplugged it and it went black again. I could never get it to turn back on.
    Hopefully yours won't react like mine did, but will come back on after an extended time on the charger.
    Thanks for the tip. I took it to Sprint and they said they would look at it and either fix it, or replace it for $35 save for water damage. Well, the phone had no water damage so they ordered me a new phone. I was glad to pay $35 for a new photon.
    Should be here this week.
    Question!
    My phone is rooted and also happens to have some important docs on it. I have it backed up, but the data is still on my phone. what happens to my old phone, is it sent back to moto for diss assembly and repair? And what of my stuff on the phone? Nothing on the phone is detrimental or top secret, but it does have copies of my documents and other stuff.
    Since the phone won't turn on, I suspect there is no way to restore factory settings and delete my stuff.
    Thanks
  7. #7
    tirith's Avatar
    Posts
    ROM
    Default
    When they send it in to be refurbed, they basically get it to work and flash whatever version they are currently running. They SHOULDN'T go through it, but no promises there... (I'd hate to think of them going through mine... They'd find a lot of pics of my fiancee...)
    Sent from my MB855 using Tapatalk 2
  8. Thread Author  Thread Author    #8
    lol,
    They said the phone is on back order. So they said it could be another 10 days. Think I'll be lucky enough to get ICS ???? not!
  9. #9
    Yeah, when I took mine to BB, the Photons were on backorder, so they just gave me a new one there. Wonder if they could check to see if any other Sprint stores have any Photons in stock so you don't have to wait for another one. And, I wonder if they are even making any more???
    ICS, I wish!!! I was a little sad when BB told me they were going to just give me a new phone because I was kind of looking forward to using my Pre again. Oh how I miss that OS.
