Results 1 to 4 of 4
    dorelse's Avatar
    Posts
    Global Posts
    238 Global Posts
    Default JB or ICS on Photon in Sprint Help
    Anyone else get this from Sprint and notice...that isn't GB? (I'm fuzzy on how ICS or JB looks on the homescreen, so I don't know which this is.)
    I realize its likely a photoshop'd image from Sprint...but...there it is:
    Last edited by dorelse; 09-07-2012 at 12:36 PM. Reason: Nothing to see here...Sprint thinks the Photon 4G & Photon Q are the same...
  2. #2
    lapk78's Avatar
    Posts
    Global Posts
    37 Global Posts
    Default Re: JB or ICS on Photon in Sprint Help
    Is that the Photon Q?
    dorelse's Avatar
    Posts
    Global Posts
    238 Global Posts
    Could be now that you say that...
    so...Sprint's sending me instructions on my phone, Photon 4G, but picturing the wrong model, the Photon Q.
    Yep, I think you're right, ear piece isn't right for ours is it?
    That's frustrating...I'll delete this in a bit.
  4. #4
    Yep, that looks like my Q with the default wallpaper. It is running ICS, which is something I am liking, it is a bit more like the webOS on my old pre.
