Results 1 to 5 of 5
Like Tree1Likes
  • 1 Post By Hvacmanjc
    Default Lock screen help
    Hello all. I downloaded one if the custom lock screen lockers and now can't figure out how to apply it. Does anyone know how this us dine? Thanks in advance
    Sent from my MB855 using Android Central Forums
  2. #2
    DroidXcon's Avatar
    Posts
    ROM
    Stock for now
    Default Re: Lock screen help
    Quote Originally Posted by Hvacmanjc View Post
    please let us know which one you downloaded
    If i've made life easier buy me a Macchiato
    Its one of the Go Locker lock screens
  4. #4
    DroidXcon's Avatar
    Posts
    ROM
    Stock for now
    I think you need to download the Go launcher and hold down the home screen and a menu will pop up select the locker option, select the locker you want and apply. some of them are paid, other you need to download a whole bunch of apps before you have enough credit to use it, others are simply free. let me know if that helped or not
    Thanked by:
    I figured it out. I had to go in to the Go Locker app and change it. Thanks for the help and quick response. :thumbup:
    DroidXcon likes this.
  1. Lock screen help needed.
    By monkeyluis in forum General Help and How To
    Last Post: 08-26-2012, 03:42 PM
  2. Lock screen help
    By JeezyCreezy in forum LG Optimus S
    Last Post: 11-28-2011, 05:49 PM
  3. Lock screen help requested...
    By weirdherald in forum Sprint Photon
    Last Post: 09-14-2011, 10:15 PM
  4. Alarm on Lock Screen Help
    By pittsm in forum AT&T Captivate
    Last Post: 02-09-2011, 08:05 AM
  5. lock screen help
    By syrguy1969 in forum Verizon Droid Incredible
    Last Post: 05-02-2010, 07:52 PM
