Disable the camera shutter sound
Here's an apk I found when browsing other forums. Installing it will disable the camera shutter sound (no root required). Make sure you have "Unknown sources" checked under application settings.
[Only registered and activated users can see links. Click Here To Register...]
Re: Disable the camera shutter sound
I use camera360 which takes better pictures than the stock app and it doesn't make a sound just in case people are wary of this.
However I used this on my photon 4g and it does exactly what he says it does.
Did not work on my Note 2
Because it's for the photon...
For the note, easiest way is to root and get rid of the shutter sounds in root explorer
~swyped from my galaxy note 2 on the now network
Hi is it possible for me to root my note 2 disabel the shutter and then unroot?
Thanks
Yes there are directions in the note 2 forum
Sent from my SPH-L300 using Tapatalk 2
No need to do all those complicated stuff (I am talking about Note 2 only)
You'll love this:
Change the sound icon either to "Vibrate" or "Mute" - when taking photographs -- as simple as that !!!
( you find this icon beside the Wifi, GPS, Screen Rotation, Bluetooth etc icons)
Have fun!
:cool:
It doesnt work.
Even when i have my headphones in I can still hear the sound.
Dude, didn't work on my samsung galaxy epic stock camera or my PCS camera I installed.
