Results 1 to 23 of 23
Like Tree1Likes
  • 1 Post By moonoverparma00
  • 1 Post By zmann
  • 1 Post By Tony tata
    Default Sprint Note 3: Battery life
    I just bought my phone a month ago. Up until yesterday my battery has been awesome. Now all of a sudden it's dying really fast. Just typing this I've lost 3%!
  2. #2
    Default Re: Battery life
    It seems to be ever since the KitKat update that the battery life isn't as good. I just got mine a week ago so I can't compare how it was with Jellybean. The phone updated as soon as I got it.
    rivencap likes this.
  3. #3
    UJ95x's Avatar
    Retired Ambassador
    Posts
    Global Posts
    10,442 Global Posts
    Carrier
    Stock 6.0.1
    Quote Originally Posted by Ricewar View Post
    Welcome to Android Central
    Could you post screenshots of your battery stats? If anything weird stands out it should be an easy fix
    Sent from my Galaxy S4 running SlimKat 4.4.2
  4. #4
    Welcome to Android Central. Verizon still has the Note3 on JellyBean and battery life is pretty good. Have you tried removing the battery for 30 seconds...I read in these forums that it tends to bring back better battery life. Not exactly sure though.
  5. #5
    As UJ95X said, post your battery stats, I have experienced the same awesome battery life under both JB and KK, I'm sure someone can help identify your problem if you supply more information
  6. #6
    Default Re: Sprint Note 3: Battery life
    As moonover posted, this is starting to be a valid complaint of the kit kat update if that is what you are running. And as other posters suggested, post screen shots of your battery stats. There might be a quick fix.
    Palm Treo line > BlackBerry line > Samsung Galaxy S line > NOW the awesome & powerful Samsung Galaxy Note 3! 😆📱😆
  7. #7
    My battery has actually gotten even better since kit kat update.
    THE BEAST,,NOTE 3. SIZE IS EVERYTHING!!!
    Ntchwaidumela likes this.
  8. #8
    My battery life got pretty bad. Not sure how to post a screen shot on here. But after only 4 hrs I'm at 81% battery life and it says android system is using 30 % of the battery
  9. #9
    Here it is
    Sent from my SM-N900P using AC Forums mobile app
    Attached Thumbnails Attached Thumbnails Sprint Note 3: Battery life-1394692203497.jpg
  10. #10
    UJ95x's Avatar
    Retired Ambassador
    Posts
    Global Posts
    10,442 Global Posts
    Carrier
    Stock 6.0.1
    Quote Originally Posted by Tony tata View Post
    Here it is
    How much screen time did you have at the time?
  11. #11
    I always have it set to sleep after 2 minutes. If that's what your askin
  12. #12
    UJ95x's Avatar
    Retired Ambassador
    Posts
    Global Posts
    10,442 Global Posts
    Carrier
    Stock 6.0.1
    No. I mean out of the four hours the phone was on, how long was the screen on?
  13. #13
    This is what Kitkat has done to my Note 3
  14. #14
    Quote Originally Posted by zmann View Post
    I think you're the only one.
  15. #15
    Bond32's Avatar
    Posts
    Global Posts
    1,390 Global Posts
    Carrier
    Stock unrooted
    I've had my note 3 now for a few days. Honestly I wasn't as blown away as I had hoped by battery life. Sure it's not bad, maybe it's because I have been on it so much. At any rate I love the phone. Might even get the 10k mah battery just because I want to see how long it will go.
    Sent from my SM-N900P using Tapatalk
  16. #16
    Quote Originally Posted by Bond32 View Post
    😲 they sell that?
  17. #17
  18. #18
    Wow
  19. #19
    Battery Life sucks after KitKat update. Hope they come out with a fix
  20. #20
    I've had my note 3 since November. I run the heck out of it and the battery lasted all day until KitKat. Now the battery lasts just a few hours. Gets hot, have removed the battery, what else to do? Something is running that I can't see, can't close. There is a definite negative difference since the update.
  21. #21
    Doing the clear cache helped me out. Brought it back to normal. The instructions in this thread
  22. #22
    We have battery issues since the KK update as well. I looked thru thread and did not see the clear cache info. Could you post it please? Thanks.
  23. #23
    This is the instructions. Worked for my sprint phone
    Attached Thumbnails Attached Thumbnails Sprint Note 3: Battery life-1395070355215.jpg
    tee52 likes this.
  1. HTC One: TERRIBLE battery drain - worse after KitKat
    By reptar fingers in forum HTC One M7
    Last Post: 05-02-2014, 01:59 PM
  2. Droid MAXX: acceptable / normal battery life?
    By lgbalfa in forum Motorola Droid MAXX
    Last Post: 03-10-2014, 12:05 PM
  3. Note owner 4 life here!
    By HothTron in forum Introductions
    Last Post: 03-10-2014, 02:02 AM
  4. Note 3: Idle time battery useage.
    By Jalopiejoe in forum Samsung Galaxy Note 3
    Last Post: 03-09-2014, 01:15 PM
  5. Moto X: Battery usage
    By eric002 in forum Moto X (2013)
    Last Post: 03-08-2014, 01:46 PM
