Results 1 to 11 of 11
Like Tree8Likes
  • 3 Post By Patrick Schroedl
  • 1 Post By dpham00
  • 1 Post By UJ95x
  • 3 Post By Kevin OQuinn
  • 2 Post By Patrick Schroedl
    Default Help with color on my phone
    My Samsung Galaxy note 3 said it needed to upgrade something and when it started back up my screen was black and my battery icon, WIFI and others things are like a negative gray. I want my white color back with my white phone. How to I get it back?
  2. #2
    UJ95x's Avatar
    Retired Ambassador
    Posts
    Global Posts
    10,442 Global Posts
    Carrier
    Stock 6.0.1
    Default Re: Help with color on my phone
    Quote Originally Posted by Amanda Johnson4 View Post
    Welcome to Android Central
    Could you post screenshots of what it looks like?
    Sent from my Galaxy S4 running SlimKat 4.4.2
  3. #3
    Patrick Schroedl's Avatar
    Retired Moderator
    Posts
    Global Posts
    3,828 Global Posts
    Quote Originally Posted by UJ95x View Post
    This will be the fastest way for us to identify what the issue is. For reference, you can grab a screenshot by holding the power and home buttons down simultaneously until you see/hear the capture. I would also ensure that the "negative colors" setting is disabled, it may have been turned on inadvertently:
    Settings > Device > Accessibility > Negative colors
    UJ95x, Johnly and dpham00 like this.
  4. #4
    UJ95x's Avatar
    Retired Ambassador
    Posts
    Global Posts
    10,442 Global Posts
    Carrier
    Stock 6.0.1
    Quote Originally Posted by Patrick Schroedl View Post
    This is what it sounds like to me. Didn't know it was an option in stock TouchWiz
  5. #5
    Palm motion should also work for screen shot if enabled. Some might prefer it over the home+power button method
    dpham00, Android Central Moderator
    Sent from my Verizon Samsung Galaxy Note 3 via Tapatalk Pro
    Nope it was the Android 4.4.2 that is screwing with my phone. I can't type on my online banking. It is showing in black and not letting me type and also taking a while to select something
  7. #7
    UJ95x's Avatar
    Retired Ambassador
    Posts
    Global Posts
    10,442 Global Posts
    Carrier
    Stock 6.0.1
    Reboot into recovery mode (Volume up + home + power) and wipe the cache partition. See if that helps with the delays. It won't delete any user data so you don't need to back any thing up
    Golfdriver97 likes this.
  8. Thread Author  Thread Author    #8
    How often does the Android software update? I am not liking the 4.4.2
  9. #9
    UJ95x's Avatar
    Retired Ambassador
    Posts
    Global Posts
    10,442 Global Posts
    Carrier
    Stock 6.0.1
    Not very often. At least major changes, so I wouldn't expect anything soon. Maybe 5-6 months at the earliest (for the Note 3)
  10. #10
    Kevin OQuinn's Avatar
    AC Team Emeritus
    Posts
    Global Posts
    9,908 Global Posts
    Carrier
    Stock
    I suspect that over the course of the next couple of days you'll get used to it.
  11. #11
    Retired Moderator
    Posts
    Global Posts
    3,828 Global Posts
    Quote Originally Posted by Kevin O'Quinn View Post
    Thankfully the changes in 4.4.2 itself are relatively minor on the surface, so as Kevin said, you'll probably be used to it in no time. I'd say the improvements under the hood, so to speak, are likely worth the adjustment to UI changes — though some may say otherwise.
    Golfdriver97 and UJ95x like this.
  1. Should I root my Moto X?
    By ONLYuseBB10 in forum Moto X Rooting, ROMs, & Hacks
    Last Post: 02-02-2015, 04:52 PM
  2. Please Help With Photo Contact
    By Crimson2 in forum Moto G (2013)
    Last Post: 01-28-2015, 10:36 AM
  3. Please someone Help! ("no service" after flashing)
    By Sivert Holmvik in forum Samsung Galaxy Note 3
    Last Post: 03-18-2014, 08:16 PM
  4. What's The Easiest Way to Get Music on S3 Mini?
    By Chris Bates1 in forum Samsung Galaxy S3 Mini
    Last Post: 03-16-2014, 03:37 PM
  5. can you guys help me with a tsak for tasker?!
    By a7medabdou in forum Android Apps
    Last Post: 03-15-2014, 01:56 PM
