Results 1 to 5 of 5
    Default Auvio MHL Adapter not working with my note 3
    Help please! Just purchased the auvio MHL adapter from radio shack so I could connect my note 3 to the tv. Hooked everything up perfectly but it's not working. Is it not compatible? Am I doing something wrong? Can I get some help in this issue please thanks.
  2. #2
    Default Re: Auvio MHL Adapter not working with my note 3
    Does the packaging say it will work with the Note 3?
    Sent from my T-Mobile Note 3 using AC Forums.
  3. #3
    Dont know if this helps but I know Best Buy sells the Rocketfish one that comes with a Samsung adapter. Im wondering if the pin layout is different on yours and thats why it wont work.
  4. #4
    For the note 3 it needs to be mhl 2.0 or above... I believe 3.0 is coming out or is now out. The problem is that mhl 1. Worked on 1 amp. 2.0 works on 2 amps. Most mhl 1 adapters will not say what version they are but you can look at the amps and take a guess. I would not buy one unless it specifically says 2... whatever or above. I have not bought one yet and may not I am looking at getting a chrome cast which should be able to do the same thing without the cord. The older version just doesn't have enough power to run the note 3 and I am sure there are other differences.
    Just so you know...... Same thing with any charger you buy for your note 3 it needs to be at least 2 amps. In all honesty I would not buy one that was below 2.1 amps. A 1 amp charger may charge your phone but it will be very slow and you risk overheating your charger and the possibility of starting a fire. I have found that in an emergency sometime soon it will work but I only left it plugged in for 10 minutes and it only charge 1% . Not taking any chances.
  5. #5
    Yeah, I bought one to for my Galaxy S5 and my Galaxy Tab 3.....After I bought it, I was looking at the booklet. It looks like it was mostly geared toward a Galaxy S3....Anything newer than that probably isn't compatible...of course, the jerkoffs at Radio Shack don't tell you that. They just let you buy it.
    I took it home and sure enough, it doesn't work on either of my devices either. On my way to return it now.
  1. Samsung galaxy not 2 help
    By deevegas in forum Verizon Galaxy Note 2
    Last Post: 03-20-2014, 07:20 PM
  2. Problem transferring files BACK ONTO SD card from PC (Note 3 files)
    By Psuranto in forum General Help and How To
    Last Post: 03-19-2014, 11:37 PM
  3. Not receiving calls from certain phone numbers.
    By robwithtoast in forum Google Nexus 4
    Last Post: 03-19-2014, 06:18 PM
  4. Organising my music
    By TheJordanDenton in forum General Help and How To
    Last Post: 03-19-2014, 12:08 PM
  5. [FREE] Stargraffiti - draw a picture with stars!
    By tar_ya in forum Android Apps
    Last Post: 03-19-2014, 11:16 AM
