1. nicts89's Avatar
    How is battery life on this so bad! I used to have an S4 and a moto and neither were this bad! I'm getting barely 6 hours! Here's a pic from earlier today... Any help? I just bought this phone and updated to Kit Kat BTW.
    Sent from my SM-N900P using AC Forums mobile app
    Attached Thumbnails Ughhh!!! This can't be right!  (Poor battery life on Galaxy Note 3)-1397179592922.jpg
    04-10-2014 08:26 PM
  2. Aquila's Avatar
    Can you please tap the chart and screenshot the screen that comes up there?
    04-10-2014 08:31 PM
  3. mrsmumbles's Avatar
    Something is making Android System overwork. It can be hard to figure out the culprit. You could try rebooting the phone, or shut it off and remove the battery for a few minutes before turning it back on, and see if it helps.
    Sent from my Nexus 5 using Tapatalk 2
    Ntchwaidumela likes this.
    04-10-2014 08:32 PM
  4. B. Diddy's Avatar
    Welcome to Android Central! Can you also show us screenshots of your total screen time (just tap Screen) and the detailed battery graph that also shows your cell signal? Screen is the biggest battery drain in general, and a poor cell signal will also drain your battery.
    Also, does this behavior continue after a reset? One thing to consider would be a cache partition wipe, which won't erase any personal data: https://support.t-mobile.com/docs/DOC-9049
    04-10-2014 08:33 PM
  5. dpham00's Avatar
    Download gsam, and post screen shots. Also, in addition to screen on time, screen brightness plays a big roll. For reference from my note 3.
    dpham00, Android Central Moderator
    Sent from my Verizon Samsung Galaxy Note 3 via Tapatalk Pro
    04-10-2014 08:45 PM
  6. nicts89's Avatar
    Thanks for all the help everyone! Here's a pic from today... This includes about 3 sessions of charging throughout the day!
    Attached Thumbnails Ughhh!!! This can't be right!  (Poor battery life on Galaxy Note 3)-1397181345625.jpg
    04-10-2014 08:55 PM
  7. nicts89's Avatar
    Here's gsam!
    Attached Thumbnails Ughhh!!! This can't be right!  (Poor battery life on Galaxy Note 3)-1397181526074.jpg
    04-10-2014 08:58 PM
  8. B. Diddy's Avatar
    For GSam, you'll need to post another screenshot after you've charged up completely and then used it down to 10-20% again. The stats you show there only account for the last minute, which is presumably when you installed it.
    What's your total screen-on time been?
    04-10-2014 09:15 PM
  9. Aquila's Avatar
    This clarifies it a lot. The 4 hours from the original shot is from the last time it was taken off of the charger at roughly 50%. There are two main causes of the battery issue that are apparent even prior to seeing what GSAM comes up with when you get it fully charged and through a couple of cycles - The screen is on almost constantly or being toggled on/off all day long and thus the device is awake almost constantly as well. I don't see any real evidence of wakelocks but it looks like the device is in heavy use for about two hours at a time approximately 4 times during that 14 hour screenshot.
    04-10-2014 09:22 PM
  10. nicts89's Avatar
    It was about 1. 45 hours in the first picture... I'll have to redo a test once I charge up the battery
    04-10-2014 09:24 PM
  11. Golfdriver97's Avatar
    You just bought the phone today? One thing to keep in mind is the battery will need a few charge cycles to get into the swing of things.
    The second thing I am seeing is a relatively poor cell signal. Even though this is a smartphone, at its core, it is still basically a phone, and will kill itself to hold onto a cell signal, no matter how weak.
    Third, I see a couple wakelocks, but very, very minor. I would focus more on the first two things I outlined as opposed to the wakelocks.
    From a Sprint Moto X using AC Forums app
    04-10-2014 09:36 PM
  12. nicts89's Avatar
    Thanks! I'm just really confused by this though. I owned a S4, Nexus 5, and a Moto X before and none of them were as bad as the note. I know there was a big hit with the Kit Kat update but I didn't know it would be this drastic. I bought this phone mainly for the battery (after I accidentally smashed my Moto x's screen) and it's really disappointing me. If this keeps up I'm might return this and get a G2. I hope I can find a fix!
    04-10-2014 09:41 PM
  13. Closingracer's Avatar
    I would just do a warranty exchange and stick on 4.3 IMO while the battery life isn't terribly different I found 4.3 better
    Sent from my SM-N900T
    04-10-2014 09:45 PM
  14. nicts89's Avatar
    I would but I had to eBay this phone...ouch! The price of cracking your old phone
    04-10-2014 09:59 PM
  15. Closingracer's Avatar
    I personally never buy used phones since I think I rather pay full price for them over paying less for it but of it screws up your on your own.
    04-10-2014 10:22 PM
  16. Closingracer's Avatar
    I only been off charge for 5 hours but with 4 hours of screen time is great with 48% left with kitkat. I would give it a few cycles and see if it gets better
    04-10-2014 10:23 PM
  17. nicts89's Avatar
    Is this normal? I was just doing some light Web browsing on wifi with low brightness. Note that Bluetooth, gps, and all other Samsung gimmicks are turned off.
    Attached Thumbnails Ughhh!!! This can't be right!  (Poor battery life on Galaxy Note 3)-1397224779786.jpg
    04-11-2014 08:59 AM
  18. B. Diddy's Avatar
    You're right, that doesn't look that good. Show us the stats after using it more throughout the day, when the battery's down to about 20-30%.
    04-11-2014 10:13 AM
  19. Closingracer's Avatar
    I get about 6-7 hours of battery life with my phone while having high brightness on and using it heavily ( like screen on 90% during that time)
    04-11-2014 11:47 AM
  20. nicts89's Avatar
    Here's after a few phone calls and a gym session while listening to music.
    Attached Thumbnails Ughhh!!! This can't be right!  (Poor battery life on Galaxy Note 3)-1397237056324.jpg
    04-11-2014 12:24 PM
  21. robber's Avatar
    Brutal.
    Hard reset and try again. If it keeps going like this there must be some sort of hardware problem.
    04-18-2014 12:39 PM
  22. B. Diddy's Avatar
    Any followup on this? That battery life is clearly subpar, and is suggestive of some hardware or system flaw.
    04-18-2014 12:43 PM
  23. NoNexus's Avatar
    I agree hardware is the issue, faulty battery?
    04-19-2014 07:59 AM
  1. Can my note 3 control. ..
    By Brockly in forum Samsung Galaxy Note 3
    Last Post: 04-11-2014, 09:10 AM
  2. Battery cycle
    By WildCatBBN3 in forum HTC One M8
    Last Post: 04-10-2014, 09:28 PM
  3. Galaxy S3 Splash Screen then Nothing
    By ncwitz in forum Samsung Galaxy S3
    Last Post: 04-10-2014, 07:36 PM
  4. "Unfortunately (app) has stopped working" on 4g but not WiFi
    By thunderbunder16 in forum Samsung Galaxy S4
    Last Post: 04-10-2014, 07:32 PM
  5. Sale on Sprint Galaxy S5 at Sam's Club on 4/11/201
    By ab304945 in forum Samsung Galaxy S5
    Last Post: 04-10-2014, 06:36 PM
