Results 1 to 3 of 3
    Default How to fix boot loop issue after flashing with Cyanogenmod 11 nigtly
    I have Samsung Note 3 from Sprint, which I have rooted and installed custom recovery twrp 2.6.x.x. Now, I am trying to install Cyanogenmod 11 nightly and I keep seeing the message: unable to moutn e:/usbstorage. And I think this is messing with my attempt to install Cyanogenmod 11 because after install, the phone is caught in a boot loop. I went into recovery and wiped data and delvic cache but nothing changed. I checked the MD5 hash of Cyanogenmod and it is good. I have also tried older versions from the same nightly page. I just get this one error. When I flash the phone, if I ask twrp to check the MD5, it fails. If don't ask for it, it says that there is no hash file and reports that install was a success. But instead the phone goes into a boot loop. The twrp install / flashing process seems to take a short time. I have done this once, and had to revert back to stock; from what I recall last time it took a little longer to flash the phone with another rom. I saw this link about the same issue on a different phone. Here is the link Script / Fix Soft Brick Loop_ EFS partition_01.11.13 =noteSome of the people on the site say that the script worked for their Note 3. Others say that the script is not for Note 3. Regardless, I tried it but nothing changed. I need help to fix this issue. I do have a stock image to flash my phone if anything breaks. I also have the rooting and twrp flashing tools and procedures. I do it in my sleep now. I do not know if I should start messing with PIT files. This site has procedures for fixing a boot loop; I tried it but did not fix my issue. How to Install Stock Firmware on Galaxy Note 3 (All Models)
  2. #2
    Golfdriver97's Avatar
    Posts
    Global Posts
    32,707 Global Posts
    Carrier
    Pure Nexus/Franco Kernel
    Default Re: How to fix boot loop issue after flashing with Cyanogenmod 11 nigtly
    Quote Originally Posted by zohal52 View Post
    Welcome to the forums.
    When you installed CM, did you wipe cache, dalvik and do a factory reset?
    To fix this, you probably are going to have to reflash a stock ROM, and I don't think you need to worry about a PIT file. Reflash, reroot, reflash TWRP, then try again. After reflashing the custom recovery, I would make a Nandroid backup, just in case.
  3. #3
    the boot loop is no allowing my mobile to charge completely due to which i am unable to install or flash any other rom.
    can some one help me.
  1. How to sync contacts with gmail account?
    By wookiee2cu in forum Samsung Galaxy S5
    Last Post: 03-01-2016, 02:46 AM
  2. HTC One M8 on AT&T - Ongoing adventure
    By naviwilliams in forum HTC One M8
    Last Post: 10-21-2014, 09:06 AM
  3. anyone got any minor problems? here are my problems after 4th repair.
    By preppystud in forum Google Nexus 7 Tablet (2013)
    Last Post: 05-05-2014, 06:03 AM
  4. Gear 2 how to get to task manager?
    By jayonegame in forum Samsung Gear 2 & Gear 2 Neo
    Last Post: 04-30-2014, 03:40 PM
  5. Replies: 0
    Last Post: 04-29-2014, 06:59 PM
