Results 1 to 7 of 7
    Default Wifi battery consumption
    Does anyone know why this consumes 4% of my battery when I don't even have it turned on?
    Sent from a device beyond your wildest dreams!
  2. #2
    Default Re: Wifi battery consumption
    Are you using any location-aware apps? Some of these can actually turn your WiFi on to get their location, even if it's just for a moment and no, you wouldn't get notified about it.
  3. #3
    Rukbat's Avatar
    Posts
    Global Posts
    22,810 Global Posts
    Carrier
    Modified Stock 4.4.2
    1) It consumes 4% of your battery, or 4% of what's consumed (which could be less than 1% of your battery) is being consumed by wifi? (The battery app shows the percentage of total use used by that service - add up all the percentages and you'll ALWAYS come up close to 100% - IOW, 100% of what's being used is being used. That could be 1% per hour of total battery capacity.) Anything using 4% of total usage is considered a VERY low battery consumer. (The CPU - just idling, not "doing" anything - uses about that much.)
    If wifi is consuming 4% of your battery per hour, that's abnormal even if it's on and connected. That would probably indicate a corrupted modem (part of the firmware) or a hardware problem. The whole phone shouldn't be using much more than that.
    2) If you have scanning enabled, the wifi radio wakes up every so often to see if there are any wifi signals nearby.
    The only location app running is weather bug and I have my gps only selected, would that cause the problem?
    Is this consumed or what's consumed in regards to my battery life?
    Attached Thumbnails Attached Thumbnails Wifi battery consumption-screenshot_2014-08-18-17-11-16.jpg
  6. #6
    UJ95x's Avatar
    Retired Ambassador
    Posts
    Global Posts
    10,442 Global Posts
    Carrier
    Stock 6.0.1
    Quote Originally Posted by djdonnyk View Post
    That is 4% of what has been consumed, not 4% of your total charge. So 0.4% of your total battery capacity has been depleted by the WiFi.
    Do you have WiFi scanning on like rukbat suggested?
    Sent from my Galaxy S4 running SlimKat 4.4.4
    No Wifi scanning on at all. I just turn it on when I get home.
  1. Nook HD+ Battery issues
    By ferrumcampitor in forum Barnes & Noble Nook HD / HD+
    Last Post: 11-14-2014, 03:23 PM
  2. Battery App Recommendations
    By bhameyedoc in forum Motorola Droid MAXX
    Last Post: 08-20-2014, 12:14 PM
  3. Battery drain problems - Android OS 70% + ?!
    By Afterlife737 in forum Ask a Question
    Last Post: 08-19-2014, 11:04 AM
  4. Replies: 8
    Last Post: 08-18-2014, 09:53 PM
  5. since 4.4.2 upgrade phone won't connect to wifi
    By granthatchett in forum AT&T Galaxy S3
    Last Post: 08-18-2014, 08:14 PM
