I've had 2 different Atrix 4G phones get stuck in the reboot loop now.
If you don't notice when it starts, and left alone to continue for an hour
or two, then this will eventually heat up the phone (very hot!!).
You are correct. The message is (next to a triangle with an exclamation (!) point inside the triangle): "Sorry! Process system is not responding"
(response option buttons are "Wait" or "Force Close")
The first two times, I did a factory reset to fix it. Then I switched
phones, to a new Atrix 4G. Same problem. Now I have done several hard
resets (erases EVERYTHING and goes back to factory condition) on TWO
DIFFERENT Atrix 4G phones, and each time, I've done all kinds of
troubleshooting including attempts to isolate the cause to a single
apk. No luck.
The ONLY fix that I've found thus far, is a Factory
Reset, which is a total pain in the neck if you haven't broken the
warrantee and rooted the phone, because each and every app must be
reinstalled and reconfigured (if you have over 200 apps, that's about 4
or 5 hours of your life down the tube, and truly a tortuous
experience). How on earth did this get past a quality review by
Motorola???!!!???
PLEASE POST BACK HERE if you find a fix other than reset.
MY SYSTEM INFO:
AT&T Best Buy
System version 55.11.16.MB865.ATT.en.US
Model Number: MB8656
Android Version: 2.3.5
Baseband version:
2011-09-21 09:42 Off.Bld
LUD_EDISON_R1D7_PATCH_27_110921_0913
Webtop version WT-1.3.0-133_EDI-8
Kernel version
2.6.35.7-gac99e44
hkdp76@ca25rhe91 #1
Build number: 5.5.1-175_EDFFW1-16
apk. No luck.
Motorola???!!!???
MY SYSTEM INFO:
AT&T Best Buy
Baseband version:
Kernel version
2.6.35.7-gac99e44
hkdp76@ca25rhe91 #1
