1. 603bogart420's Avatar
    Hello everybody, i have a pretty universal question that i would just like to clarify with somebody whom has more exp. With the particular device. My initial question is, after downloading an image to the device, does this history need to stay in the downloads folder. Everytime i delete stuff from that folder, whatever i have deleted becomes fully removed from the entire device. I can only assume that this means that if i want to keep what i downlkad it must stay in the download folder.....correct? The other question. That i have is if i download word docs. Is the only place that this gets saved initially is in the downloads folder? If so what ahould i do.....save as than delete it from the folder. Or is the census that you must keep everything in that folder.
    02-28-2012 06:03 PM
