Results 1 to 3 of 3
    TawandaK9's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default No sound during calls
    My Atrix HD has developed a distressing problem. It frequently drops all sound when making calls. I will not hear the phone ringing on my end, but it rings whoever I'm calling. Once they answer, the call behaves normally, except that neither of us can hear the other at all. Redialing and resetting the phone does not help. The only thing that helps is if I turn the speaker phone on. Then I can use the speakerphone or, if I turn the speakerphone off, I can then use the handset. Haven't tested to see if Bluetooth will work after turning the speakerphone on and off, but it doesn't work otherwise.
    Yesterday I did a hard reset and the problem still persists. Any ideas?
  2. #2
    nickgalaxys4's Avatar
    Posts
    Global Posts
    414 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: No sound during calls
    I had the same thing with an old phone of mine I took it back and they restored it still had a problem so they just replaced it for me. I don't think there much you can do besides restore and see what happens. If you already did this i would go back to the store.
  3. #3
    woodslink's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    If anyone else runs into this, give SoundAbout a try. It's in the Google Play store.
  1. No sound on calls
    By newbk in forum Sprint XPRT
    Last Post: 10-19-2012, 10:09 PM
  2. Text Sound During Calls
    By godsidekurt in forum Sprint Galaxy S II Epic 4G Touch
    Last Post: 03-02-2012, 04:24 AM
  3. Replies: 3
    Last Post: 02-08-2012, 01:48 PM
  4. Incoming text msg sound during a call
    By popkurn611 in forum Motorola Droid 2
    Last Post: 09-06-2011, 12:04 AM
  5. Alarm clock sounds during call
    By reinangel in forum HTC EVO 4G
    Last Post: 06-25-2010, 10:15 PM
