Results 1 to 4 of 4
    Soham Kale's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default AT&T Atrix won't connect to WiFi
    My Motorola Mb860 won't connect to any WiFi networks, whenever I try to turn on the WiFi, it takes a while and finally says "Error". Then It proceeds to turn off by itself after a few minutes. If I use any home screen widget to turn on the WiFi, it fails and automatically turns off. The most annoying part of the turning off part is that my Atrix takes almost 5 minutes to reboot, its always stuck on the AT&T sign that comes for a long time until it finally comes to the lockscreen. Is there anyway for me too fix any of these problems, mostly the WiFi problem, that preferably doesn't need me to factory reset it? I've had the phone for about 1.5 years now.
  2. #2
    Rim85's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: AT&T Atrix won't connect to WiFi
    Did u reboot only? If yes, pull the battery and then try. Or do a factory reset.
    Sent from my MB860 using Tapatalk 2
  3. #3
    GenTsoChicken's Avatar
    Posts
    Global Posts
    157 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I've been having the same problem recently. I'm afraid if I do a factory reset it wont work and I'll have to download everything off wifi.
  4. #4
    BigJ22's Avatar
    Posts
    Global Posts
    32 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I had the same problem with mine before the screen shattered. I had to do a full reset, and even after that it still had intermittent issues.
  1. HP Touchpad/Android won't connect to Wifi
    By ZTharakan in forum HP Touchpad
    Last Post: 12-30-2013, 06:46 AM
  2. Won't connect to wifi?
    By KyleB4real in forum HTC EVO 4G LTE
    Last Post: 11-10-2013, 07:16 PM
  3. My phone won't connect to wifi... [IMPORTANT]
    By Perseveranze in forum General Help and How To
    Last Post: 11-08-2012, 10:03 AM
  4. My phone won't connect to wifi... [IMPORTANT]
    By Perseveranze in forum Samsung Galaxy S3
    Last Post: 11-07-2012, 05:37 PM
  5. Phone won't connect to wifi or 3g network
    By palmer0700 in forum Samsung Replenish
    Last Post: 04-25-2012, 01:39 PM
