[HELP] Played with WidgetLocker, phone won't come on...
Terrigno has brought my phone back from the dead, ladies & gentlemen. Sure, I lost everything. I'm going through the motoblur sign in process, and then I will see if Google will correctly retrieve my contacts and e-mails and all. The real question is whether the Market will have my previously downloaded apps in a list for me to simply redownload...I've heard conflicting stories on that. Ah, here it is, Motoblur just loaded...forgot what this looked like. Time to set up my google account and find ADW again. Its settings should be backed up to my SD card.
Terrigno, I can not thank you enough. I was about to send this thing off to Motorola...I feel so silly now. I remember with my blackberry, it seemed like this info to revive a bricked berry was very easily accessible....maybe I just missed it (multiple times. am I blind?), but I couldn't find this info you linked me to anywhere on here! I really owe you man, big time. I hope to one day be able to help another one of me out like you have. Thanks.
Reactions: Terrigno
No problem bud! Im glad I could help out. I used to run into these issues before and people with knowledge used to steer me in the right direction. Now that Ive learned up on things, I can now pay it forward. Im glad everything worked out for you!
Nick
hello there, first of all, sorry for my bad english XD
I'm new here, i got here looking for a solution to one little problem my mobile has since yesterday... well, looks like it's exactly the same problem jonneh had, you know, the text "Modem did not power up (0) Starting RSD protocol support".
My mobile discharged while i was sleeping, and when I woke up, i connected it to the charger, hoping it would charge, and then the mobile turned on and got stuck on that screen. Can you help me, please?
Can you or Terrigno tell me what did you do to bring your atrix to life?
Mine is suffering from the same problem!
Thanks a lot.
r3dpuk3
