Results 1 to 3 of 3
    Unhappy Help!! My Samsung Captivate doesnt work
    I have a Samsung Captivate that got ruined when i restarted it. I deleted some apps with titanium without knowing. it started acting funny so i restarted it and it just relooped the AT&T logo over and over again. I ourchased a USB JIG recently and this is what i did when i got it
    Start from the bottom
    any help is appreciated. thanks in advance.
  2. #2
    cyanogen-man's Avatar
    Posts
    ROM
    ice cold sandwich aokp
    Default
    Hmmmmm hold down the volume down button and press the power button and reboot into recovery hopefully you have rom manager installed and a way to put a custom rom on a sd card as you can go to flash new rom and dig one out of your sd or better yet your on a custom rom and you backed up a nother one
  3. #3
    Posts
    ROM
    Default
    Ok i just lookex at the pictures idk what the hell your running but see if you can flash a nother rom from the sd card
