Results 1 to 3 of 3
    ab304945's Avatar
    Posts
    Global Posts
    1,583 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default possible brick! please help
    Was returning to stock rom using odin 1 click. Someting happened and now the phone says firmware upgrade failed try recovery.
    Everytime i go to recover shows the same.
    Also when going into download mode, I have that jig that forces it into download mode. But still shows the firmware upgrade fail
    please help thanks
  2. Thread Author  Thread Author    #2
    ab304945's Avatar
    Posts
    Global Posts
    1,583 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: possible brick! please help
    someone said that it is download mode,just looks different.
    I run odin and it starts,
    just sits at set pit file.
    And next to dives in odin it says set partition
    It just stays like that let it sit for 15 min and still at it, tried 3 diff odin files
    ab304945's Avatar
    Posts
    Global Posts
    1,583 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    not it wont even turn on. The jig to get to download mode no longer works.
    either the battery is dead or it is bricked for sure.
