Results 1 to 2 of 2
- 07-07-2012, 06:50 PM
Thread Author #1
ROM HELP!!!!!!!!!
I am using a samsung captivate i987, modded recovery with no check for signatures on zips, on froyo. I am new to flashing custom roms, and I'm trying to flash dark knight. I used ROM Manager to get clockwork recovery, now it says it is installing the rom, but it is in a loop. it:
brings up the att screen
goes black
brings up att screen
brings up, what looks like i guess the terminal where it installs, in a matter of half a second in runs through bout ten lines then goes blank, and back to the top.
Is this bad, correct? It will stop doing it after about ten times, then I press and hold the power button to turn it on and it cycles through again. Wjat the Heck!?!?!?!? - 12-17-2012, 12:33 PM #2
Reply
