Results 1 to 14 of 14
- 02-06-2011, 11:00 PM
Thread Author #1
- 02-06-2011, 11:04 PM #2
- 02-06-2011, 11:13 PM
Thread Author #3
sorry, forgot to add that. I did already download the rom manager and flashed the clockwork recovery.
I went back in just now, reflashed the recovery, then used the rom manager to access the new rom on the external sd card, went into recovery thru the rom manager, still nothing worked.... - 02-06-2011, 11:52 PM
Thread Author #4
watched another couple videos online, figured out that it was the internal sd card, not external....... re tried everything, still not working, same error.
I am wondering about the update.zip file on my sd card, that may be hanging me up, going to try removing it..... hope for the best. - 02-07-2011, 12:00 AM
Thread Author #5
well that didn't work, put the update file back onto the internal sd card, back to where we started. this is getting really annoying...........
- 02-07-2011, 12:02 AM #6
let me watch what they told you to do
- 02-07-2011, 12:06 AM #7
are you sure this works for the rogers version?
- 02-07-2011, 12:15 AM
Thread Author #8
I would have thought it would be the same? it's essentially the same phone as at&t, and the write up is showing it as working for both vibrant and captivate, so I would think it should applie.....
- 02-07-2011, 12:17 AM #9
- 02-07-2011, 12:45 AM
Thread Author #10
ok, good video so far. he showed that you need to be in the debugging mode, i was in the keis mode to tranfer the files. Of course, now that I figured that out, I ran into another problem....
error 0x80070057
I get this as I try to drag the .zip file into the sd card, wont let me drop it in.... - 02-07-2011, 12:55 AM #11
- 02-07-2011, 01:20 AM
Thread Author #12
did some digging, it seems this error is supposed to be s registry file error. So I downloaded registry mechanic, ran the full scan, cleaned up all the registry problems, re-ran the scan, nothing else showing. Problem solved, go to transfer my file over, and the same damn code comes up!!!!
Now I'm getting really frustrated with this entire process, and an going to bed before I end up breaking something. An entire day wasted, hours spent trying to flash a custom rom, and I have absolutely nothing to show for it.......... - 02-07-2011, 01:53 AM
Thread Author #13
new kies update installed, can't see how to transfer data, just media files. Can't get anywhere with that either it seems.
- 02-07-2011, 08:53 AM #14
Reply
