1. ls377's Avatar
    This thread will server as a master list of ROM's, Kernels, Themes, and Other Mods.
    Post #1 = Index
    Post #2 = FAQ
    Post #3 = ROM's
    Post #4 = Kernels
    Post #5 = Themes
    Post #6 = Other Mods
    If you have/know of something that is missing from this list, post a link in the thread, and I'll add it ASAP.
    NCARCER8EM likes this.
    02-24-2011 01:14 PM
  2. ls377's Avatar
    ROM's:
    Q: What is a ROM?
    A: The ROM or OS is the image of the operating system. Example, Honeycomb, Gingerbread, Froyo, Eclair, Donut and Cupcake these are considered the ROM. The term ROM(s) is usually used in the rooting and hacking community when referring to a modified or custom version of the original ROM/OS.
    Q: What's the difference between Captivate based and I9000 based?
    A: Captivate based uses the official Froyo release. I9000 is the European Galaxy S, and is ported to the Captivate by the developer. I9000 based brings more up-to-date software, but may be more buggy.
    Kernels:
    Q: What is a kernel?
    A: In simple terms, a kernel is the main link to the ROM (OS) and tells it what to do and how to do it. Aside from stock kernels, modified kernels are used for overclocking the speed of processor and controlling of voltage usage, resulting in better battery life and other settings.
    Themes:
    Q: What is a theme?
    A: A theme is a makeover of the ROM's UI (user interface) by means of changing backgrounds, text colors, icons, overall appearance. This could also include battery display mods, and other neat additions.
    Other Mods:
    Q: What is other mods?
    A: This could be modified stock ROM applications, startup & shutdown boot animations and application restores/reverts & other misc. changes that can be flashed or installed.
    optimusmatticus likes this.
    02-24-2011 01:15 PM
  3. ls377's Avatar
    Due to the ridiculous amount of ROMS available, this will only include ROMS that are still supported by the developer.
    CAPTIVATE/ROGERS BASED ROMS
    OS Base: Froyo KB1 (2.2)
    General Notes:To download a ROM just click on the "Location" link and it will take you directly to the ROM developers page.
    Rom Name: Cognition 4
    Developer: DesignGears
    Discussion: http://forum.androidcentral.com/t-ca...cognition.html
    Rom Name: FireFly 3
    Developer: xtremekilla09
    Discussion: http://forum.androidcentral.com/t-ca...m-firefly.html
    I9088 BASED (Chinese Captivate)
    Rom Name: Dragon
    Developer: DAGr8
    Location/Discussion: Android Central
    I9000/ARMANI BASED ROMS
    OS Base: Froyo JPY/JS5/JL1 (2.2.1)
    Rom Name: Serendipity [FINAL]
    Developer: MikeyMike01 & ChanceM
    Discussion: http://forum.androidcentral.com/t-ca...rendipity.html
    Rom Name: Andromeda
    Developer: Team Komin
    Discussion: http://forum.androidcentral.com/t-ca...andromeda.html
    Rom Name: Supernova 2.3
    Developer: adamholden85
    Discussion: http://forum.androidcentral.com/t-ca...supernova.html
    Rom Name: Pheonix Rising v5.2
    Developer: Team Pheonix
    Discussion: http://forum.androidcentral.com/t-ca...ix-v3-5-a.html
    I9000 GINGERBREAD BASED
    [WARN]These ROMs require flashing new bootloaders onto your device. THIS CAN BE DANGEROUS. Make sure you know what you're doing before flashing these ROMs.
    See this thread more more info.[/WARN]
    Rom Name: Continuum 5
    Developer: icezar1
    Location: [ROM][2.3.3][JVB][5/3/2011]►Continuum5.1◄Gingerbread►Captivate i897/i896/i9088◄ - xda-developers
    Discussion:http://forum.androidcentral.com/t-ca...ngerbread.html
    Rom Name: Serendipity 7
    Developer: MikeyMike01/ChanceM
    Discussion: http://forum.androidcentral.com/t-ca...ipity-vii.html
    Rom Name: Apex
    Developer: watsaa
    Location: [ROM] [04/26] [**Gingerbread JVB 2.3.3 - ApeX 6.1 Beta**][**JS8 2.2.1 - ApeX 5.3**] - xda-developers
    Discussion: http://forum.androidcentral.com/t-ca...-rom-apex.html
    Rom Name: Perception II
    Location: [ROM][2.3.3] Perception II Beta 2 (OUT NOW) - xda-developers
    Discussion: http://forum.androidcentral.com/show...487#post875487
    Rom Name: Speed and Looks Gingerstyle
    Developer: BaDaB!ng505
    Location: {ROM}2.3.3 STRIP-OUT Gingerstyle....Testing In Action.. update 5/2/01 - xda-developers
    Discussion: http://forum.androidcentral.com/show...501#post875501
    Rom Name: SubPreSSion
    Developer: DAGr8
    Location: [ROM][5/02/11]SubPreSSioN_JVB_3 [8 locks][MIUI ADDED] LOTS OF TWEAK & VERY STABLE - xda-developers
    Discussion: http://forum.androidcentral.com/show...512#post875512
    Rom Name: Mosaic I
    Developer: Team Phoenix
    Location: http://forum.xda-developers.com/show....php?t=1061203
    Discussion: http://forum.androidcentral.com/show...395#post878395
    AOSP BASED
    OS Base: Gingerbread 2.3.3
    Rom Name: CyanogenMod 7
    Developer: CMSGS Team/Team Hacksung
    Discussion: http://forum.androidcentral.com/t-ca...nightlies.html
    Rom Name: MIUI 2.3.3 Beta
    Developer: Porting by mossination
    Discussion: http://forum.androidcentral.com/t-ca...-rom-miui.html
    02-24-2011 01:17 PM
  4. ls377's Avatar
    OS Compatibility: Froyo 2.2/2.2.1/2.3.3
    General Notes: All detailed information can be obtained from the "Flashing" link from the developer if its not provided here in the list.
    CAPTIVATE/I9000 FROYO KERNELS
    Kernel Name: Onix (formerly SuckerPunch)
    Developer: existz
    Summary: Voodoo Sound 6, 1.6Ghz OC/UV, based off Speedmod
    Pre-requisites: Rooted & ClockWorkMod installed
    Flashing: xda developers
    Kernel Name: Speedmod Captivate
    Developer: hardcore
    Summary: Sharpness Fix, Voodoo Sound
    Kernel Name: Firebird
    Developer: designgears
    Summary: Voodoo Sound, color & sharpness
    Kernel Name: OverStock
    Developer: cmenard
    Summary: Voodoo sound/color/lagfix/BLN
    Kernel Name: SuckerPunch Voodoo
    Developer: existz
    Summary: Voodoo Sound 6, UV, based off Speedmod
    CYANOGENMOD/MIUI KERNELS
    Kernel Name: Trident
    Developer: ytt3r
    Summary: OC to 1500, Voodoo sound, BLN
    Pre-requisites: CM7/MIUI
    Kernel Name: Le kernel de jour
    Developer: TheEscapist
    Summary: CM7+OC to 1600+Voodoo Sound+UV+BLN
    Kernel Name: Javelin
    Developer: ytt3r
    Summary: UC to 800 for best battery performance, Voodoo sound, BLN
    Kernel Name: Platypus
    Developer: zacharias.maladroit
    Summary: OC to 1300, UV, LED notifications (BLN),
    Flashing: http://forum.androidcentral.com/show...962#post802962
    GINGERBREAD KERNELS
    Kernel Name: Talon
    Developer: existz
    Summary: OC, Voodoo color/sound
    Pre-requisites: JVB ROM
    Flashing: http://forum.xda-developers.com/show....php?t=1050206
    Kernel Name: I9000 reoriented
    Developer: xcaliburinhand
    Summary:
    Flashing: http://forum.xda-developers.com/show....php?t=1042543
    02-24-2011 01:19 PM
  5. ls377's Avatar
    THEMES
    NOTE: Certain themes only work with certain ROMS, so read and make sure your ROM and theme are compatible.
    Themes listed here are compatible with multiple ROMS.
    Theme Name: Bloo+Pinky+The Red
    Designer: whiteguypl
    Theme Name: Dark Soul
    Designer: Plasticdarlow
    Theme Name: Generation X
    Designer: Ported by whiteguypl
    Theme Name: SecularNun Renewal
    Designer: NunHugger
    Theme Name: Darkness2.5
    Designer: ReeferMattness
    Theme Name: Cezar's Sensation
    Designer: icezar1
    Theme Name: Legacy
    Theme Name: Gingerbread Theme
    Designer: gtg465x
    02-24-2011 01:21 PM
  6. ls377's Avatar
    OS Compatibility: Froyo KB1
    General Notes: Some mods not OS specific
    Mod Name: Six Lockscreens + Power Menu
    Designer: Whitehawkx
    This includes:
    ~Six Lockscreens [Settings>Display]
    ~Power Menu
    ~AM/PM Toggle [Settings>Date & Time]
    ~H Mod [Does not replace 3g symbol! Displays H when actually using HSDPA!]
    ~Stay Awake option [Settings>Applications>Development]
    ~Kill Battery Full Pop-u
    Pre-requisites: Stock deodexed KB1
    Tools Required: CWM recovery
    Mod Name: TouchWizGTG Launcher
    Designer: gtg465x
    Summary: Modified, awesomer TouchWiz
    Pre-requisites: Root (need access to /system
    Tools Required: root explorer (or similar)
    Mod Name: Hacked Camera
    Designer: Fr4gg0r; arcangels 03
    Summary: Use Power to take pictures
    Pre-requisites: Froyo
    Tools Required: n/a
    Mod Name: PlumbBob GPS Fix
    Designer: Rrryan2
    Summary: GPS improvements
    Pre-requisites: Rooted & CWM
    02-24-2011 01:22 PM
  7. ls377's Avatar
    Reserved
    02-24-2011 01:23 PM
  8. bay_wolf's Avatar
    Thanks for putting my ROM in the thread.
    03-01-2011 10:32 AM
  9. fatchance's Avatar
    Is there a link to the stock KB1 kernel floating around
    03-03-2011 12:00 PM
  10. ls377's Avatar
    Not that I know of...you could just extract it from the ROM and flash it with SGS kernel flasher or Odin.
    03-05-2011 12:29 PM
  11. pittsm's Avatar
    any way you could update the rom list? I'm not 100% sure that all those roms are still supported by the developer.
    05-03-2011 07:27 AM
  12. ls377's Avatar
    Yeah, that's my job for today . Have to add in all those gingerbread ROMs and create new threads too.
    Sent from my Captivate
    pittsm likes this.
    05-03-2011 09:35 AM
  13. ls377's Avatar
    Everything up to date. Cleaned out some dead ROMs (I left the more popular Froyo ROMs) and added in Gingerbread stuff. If I missed anything, let me know.
    BTW, if anyone runs across a ROM that doesn't have a thread, go ahead and make one. Just use the format me and ragnorakx use for them (including the location link, we'll get yelled at if we don't have it ).
    05-03-2011 07:21 PM
  14. mrsecdegree's Avatar
    what 1 of these roms would i use for samsung galaxy s at&t SHG-I897running off 3.4.5 gb rooted . and that would let me change boot up pic and shut down pic . any info would help thanx
    05-16-2012 09:19 AM
