Results 1 to 14 of 14
- 02-24-2011, 01:14 PM
Thread Author #1
[Index] Captivate ROMs, Kernels, Themes, etc. (Updated 6/2)
This thread will server as a master list of ROMs, Kernels, Themes, and Other Mods.
Post #1 = Index
Post #2 = FAQ
Post #3 = ROMs
Post #4 = Kernels
Post #5 = Themes
Post #6 = Other Mods
If you have/know of something that is missing from this list, post a link in the thread, and I'll add it ASAP.Last edited by ls377; 06-02-2011 at 04:18 PM.
Thanked by: - 02-24-2011, 01:15 PM
Thread Author #2
ROMs:
Q: What is a ROM?
A: The ROM or OS is the image of the operating system. Example, Honeycomb, Gingerbread, Froyo, Eclair, Donut and Cupcake these are considered the ROM. The term ROM(s) is usually used in the rooting and hacking community when referring to a modified or custom version of the original ROM/OS.
Q: What's the difference between Captivate based and I9000 based?
A: Captivate based uses the official Froyo release. I9000 is the European Galaxy S, and is ported to the Captivate by the developer. I9000 based brings more up-to-date software, but may be more buggy.
Kernels:
Q: What is a kernel?
A: In simple terms, a kernel is the main link to the ROM (OS) and tells it what to do and how to do it. Aside from stock kernels, modified kernels are used for overclocking the speed of processor and controlling of voltage usage, resulting in better battery life and other settings.
Themes:
Q: What is a theme?
A: A theme is a makeover of the ROMs UI (user interface) by means of changing backgrounds, text colors, icons, overall appearance. This could also include battery display mods, and other neat additions.
Other Mods:
Q: What is other mods?
A: This could be modified stock ROM applications, startup & shutdown boot animations and application restores/reverts & other misc. changes that can be flashed or installed.Last edited by ls377; 02-25-2011 at 06:54 PM.
Thanked by: - 02-24-2011, 01:17 PM
Thread Author #3
Due to the ridiculous amount of ROMS available, this will only include ROMS that are still supported by the developer.
CAPTIVATE/ROGERS BASED ROMS
OS Base: Froyo KB1 (2.2)
General Notes:To download a ROM just click on the "Location" link and it will take you directly to the ROM developers page.
Rom Name: Cognition 4
Developer: DesignGears
Discussion: http://forum.androidcentral.com/t-ca...cognition.html
Rom Name: FireFly 3
Developer: xtremekilla09
Discussion: http://forum.androidcentral.com/t-ca...m-firefly.html
I9088 BASED (Chinese Captivate)
Rom Name: Dragon
Developer: DAGr8
Location/Discussion: Android Central
I9000/ARMANI BASED ROMS
OS Base: Froyo JPY/JS5/JL1 (2.2.1)
Rom Name: Serendipity [FINAL]
Developer: MikeyMike01 & ChanceM
Discussion: http://forum.androidcentral.com/t-ca...rendipity.html
Rom Name: Andromeda
Developer: Team Komin
Discussion: http://forum.androidcentral.com/t-ca...andromeda.html
Rom Name: Supernova 2.3
Developer: adamholden85
Discussion: http://forum.androidcentral.com/t-ca...supernova.html
Rom Name: Pheonix Rising v5.2
Developer: Team Pheonix
Discussion: http://forum.androidcentral.com/t-ca...ix-v3-5-a.html
I9000 GINGERBREAD BASED
[WARN]These ROMs require flashing new bootloaders onto your device. THIS CAN BE DANGEROUS. Make sure you know what you're doing before flashing these ROMs.
See this thread more more info.[/WARN]
Rom Name: Continuum 5
Developer: icezar1
Discussion:http://forum.androidcentral.com/t-ca...ngerbread.html
Rom Name: Serendipity 7
Developer: MikeyMike01/ChanceM
Discussion: http://forum.androidcentral.com/t-ca...ipity-vii.html
Rom Name: Apex
Developer: watsaa
Discussion: http://forum.androidcentral.com/t-ca...-rom-apex.html
Rom Name: Perception II
Discussion: http://forum.androidcentral.com/show...487#post875487
Rom Name: Speed and Looks Gingerstyle
Developer: BaDaB!ng505
Discussion: http://forum.androidcentral.com/show...501#post875501
Rom Name: SubPreSSion
Developer: DAGr8
Discussion: http://forum.androidcentral.com/show...512#post875512
Rom Name: Mosaic I
Developer: Team Phoenix
Discussion: http://forum.androidcentral.com/show...395#post878395
AOSP BASED
OS Base: Gingerbread 2.3.3
Rom Name: CyanogenMod 7
Developer: CMSGS Team/Team Hacksung
Discussion: http://forum.androidcentral.com/t-ca...nightlies.html
Rom Name: MIUI 2.3.3 Beta
Developer: Porting by mossination
Discussion: http://forum.androidcentral.com/t-ca...-rom-miui.html
**********************Last edited by ls377; 06-02-2011 at 04:18 PM.
- 02-24-2011, 01:19 PM
Thread Author #4
OS Compatibility: Froyo 2.2/2.2.1/2.3.3
General Notes: All detailed information can be obtained from the "Flashing" link from the developer if its not provided here in the list.
CAPTIVATE/I9000 FROYO KERNELS
Kernel Name: Onix (formerly SuckerPunch)
Developer: existz
Summary: Voodoo Sound 6, 1.6Ghz OC/UV, based off Speedmod
Pre-requisites: Rooted & ClockWorkMod installed
Flashing:
Kernel Name: Speedmod Captivate
Developer: hardcore
Summary: Sharpness Fix, Voodoo Sound
Flashing:
Kernel Name: Firebird
Developer: designgears
Summary: Voodoo Sound, color & sharpness
Flashing:
Kernel Name: OverStock
Developer: cmenard
Summary: Voodoo sound/color/lagfix/BLN
Flashing:
Kernel Name: SuckerPunch Voodoo
Developer: existz
Summary: Voodoo Sound 6, UV, based off Speedmod
Flashing:
CYANOGENMOD/MIUI KERNELS
Kernel Name: Trident
Developer: ytt3r
Summary: OC to 1500, Voodoo sound, BLN
Pre-requisites: CM7/MIUI
Flashing:
Kernel Name: Le kernel de jour
Developer: TheEscapist
Summary: CM7+OC to 1600+Voodoo Sound+UV+BLN
Flashing:
Kernel Name: Javelin
Developer: ytt3r
Summary: UC to 800 for best battery performance, Voodoo sound, BLN
Flashing:
Kernel Name: Platypus
Developer: zacharias.maladroit
Summary: OC to 1300, UV, LED notifications (BLN),
Flashing: http://forum.androidcentral.com/show...962#post802962
GINGERBREAD KERNELS
Kernel Name: Talon
Developer: existz
Summary: OC, Voodoo color/sound
Pre-requisites: JVB ROM
Flashing:
Kernel Name: I9000 reoriented
Developer: xcaliburinhand
Summary:
Flashing:
**********************Last edited by ls377; 05-03-2011 at 07:14 PM.
- 02-24-2011, 01:21 PM
Thread Author #5
- 02-24-2011, 01:22 PM
Thread Author #6
OS Compatibility: Froyo KB1
General Notes: Some mods not OS specific
Mod Name: Six Lockscreens + Power Menu
Designer: Whitehawkx
This includes:
~Six Lockscreens [Settings>Display]
~Power Menu
~AM/PM Toggle [Settings>Date & Time]
~H Mod [Does not replace 3g symbol! Displays H when actually using HSDPA!]
~Stay Awake option [Settings>Applications>Development]
~Kill Battery Full Pop-u
Pre-requisites: Stock deodexed KB1
Tools Required: CWM recovery
Mod Name: TouchWizGTG Launcher
Designer: gtg465x
Summary: Modified, awesomer TouchWiz
Pre-requisites: Root (need access to /system
Tools Required: root explorer (or similar)
Mod Name: Hacked Camera
Designer: Fr4gg0r; arcangels 03
Summary: Use Power to take pictures
Pre-requisites: Froyo
Tools Required: n/a
Mod Name: PlumbBob GPS Fix
Designer: Rrryan2
Summary: GPS improvements
Pre-requisites: Rooted & CWM
**********************Last edited by ls377; 03-15-2011 at 12:43 PM.
- 02-24-2011, 01:23 PM
Thread Author #7
Reserved
- 03-01-2011, 10:32 AM #8
Thanks for putting my ROM in the thread.
- 03-03-2011, 12:00 PM #9
- 03-05-2011, 12:29 PM
Thread Author #10
- 05-03-2011, 07:27 AM #11
- 05-03-2011, 09:35 AM
Thread Author #12
- 05-03-2011, 07:21 PM
Thread Author #13
Everything up to date. Cleaned out some dead ROMs (I left the more popular Froyo ROMs) and added in Gingerbread stuff. If I missed anything, let me know.
BTW, if anyone runs across a ROM that doesn't have a thread, go ahead and make one. Just use the format me and ragnorakx use for them (including the location link, we'll get yelled at if we don't have it
- 05-16-2012, 09:19 AM #14
Reply
