Results 1 to 3 of 3
    Default Need help ;-[
    i want to upgrade my rom but i cant my phone shows it..
  2. #2
    Default Re: Need help ;-[
    [How-To] Samsung Captivate Root Froyo, Install ClockworkMod and flash a custom ROM
    I think what you are running into is in Post #5. Stock 2.2 has some minor file protection in place, and you need to work around this. The post above should have everything you need.
    Thanked by:
  3. #3
    NightFalcon's Avatar
    Posts
    Global Posts
    47 Global Posts
    ROM
    Which one is it today ?
    If that information doesn't help you... go there is enough info there to help you.
