Results 1 to 20 of 20
Like Tree1Likes
  • 1 Post By konazxiii
  • 1 Post By kcrandall758
    MoonlightSoldier's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Nook: CM7.1
    Default Problem parsing the package??
    Whenever I download any non-market app, (maily trying to get netflix on my unrooted 2.1 cappy) I get the error message "There is a problem parsing the package" Nothing I do opens the actual app. Sorry if this has been ask, I just really want Netflix
    EDIT: I'm also unable to download netflix from the web market
  2. #2
    konazxiii's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Ultimatum 4.0.3
    Default Re: Problem parsing the package??
    The Netflix app doesn't work on 2.1. That explains why you can't see it in the market.
    You should be able to update to official 2.2 (via Kies Mini) and run Netflix just fine after that.
    kcrandall758 likes this.
  3. #3
    kcrandall758's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    MIUI 1.9.23, stock
    what konazxiii said
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Nook: CM7.1
    Yes, I know why it wasn't showing up and stuff, but I've never been able to figure out how to update because 2.2 was OTA. Neither computers I used would correctly download the drivers and Kies never detected my device. I'm fine with running 2.1 until I get a new phone, but I'd like to be able to use netflix which is why I've been trying to download the files off of links that I find. I'm decent with technology, I just have no idea how to update, I've followed samsung instructions and what I've found here on Android Central.
  5. #5
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    MIUI 1.9.23, stock
    yea...unless you get up to 2.2, you can't use netflix. you can do what I did when I had my cappy, and install the leaked version of 2.2. root the phone, find the leaked build, and voila. or - download the drivers from here Get Downloads, Firmware, Manuals and Software for Samsung SGH-I897ZKAATT as well as Kies Mini, and give it another whirl that way
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Nook: CM7.1
    So, I downloaded Kies Mini, I need to download the drivers to right? Doesn't a zip file require a program to open it with, and thats what kind of file the device drivers are on, so does anyone know what program I can use to open the zip file?
  7. #7
    konazxiii's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Ultimatum 4.0.3
    http://forums.androidcentral.com/e?l...token=FBzRE24H
    ^Click on the software tab, download the Kies program, install it on your Windows PC, make sure Kies is up to date, and make sure you download the drivers from Kies as well.
    After that, barring a malfunctions on your PC or device, it should allow you to install official AT&T stock 2.2. It'll either be version KB1 or KB2....either is fine.
  8. #8
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    MIUI 1.9.23, stock
    check this link for drivers: Captivate USB Drivers Links Here - Android Forums
    as far as unzipping files, windows has built in extraction methods.
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Nook: CM7.1
    Windows keeps asking me if I want to install the drivers because they can't verify its publisher, do I install it?
  10. #10
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    MIUI 1.9.23, stock
    Quote Originally Posted by MoonlightSoldier View Post
    yes
  11. Thread Author  Thread Author    #11
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Nook: CM7.1
    First, thank you a lot for helping me through this, I know it probably seems like I'm completely stupid, second, do I turn on USB Debugging like I've seen in some guides, I have it set to Kies mode already.
    EDIT: Now I went back into kies with the drivers installed and windows still says it can't find drivers, should I install the drivers to Kies when it asks me where I want to install them?
  12. #12
    konazxiii's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Ultimatum 4.0.3
    No. Just install the driver through the Kies program and move on from there- it knows where to put them automatically- it doesn't ask where, it just installs them.
    If Kies fails, you can try this.
    http://forum.xda-developers.com/showthread.php?t=963403
  13. Thread Author  Thread Author    #13
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Nook: CM7.1
    Do I just download that and use it through Kies?
  14. #14
    nbell978's Avatar
    Posts
    Global Posts
    111 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by konazxiii View Post
    [ROM] i897UCKB1 2-19-2011 - xda-developers
    If you're going to point him to ROM flashing, might as well go all out ;-)
    [ROM] I897UCKI2 [Android 2.3.5][28.09.2011] - xda-developers
    UCKI2 "stock" gingerbread leak, 2.3.5
  15. Thread Author  Thread Author    #15
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Nook: CM7.1
    Kies doesn't seem to work for me at all, but I still have no idea how to root or "flash" a ROM, If I can't even update my phone, I don't know if I'm ready for messing with my phone.
  16. #16
    konazxiii's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Ultimatum 4.0.3
    The good thing is- a solid/true Captivate "brick" is a rare bird. They are solid in terms of recover-ability.
    Truth: Rooting is technically not even necessary to flash a ROM. All you need is Odin and a proper kernel.
    I was scared/worried at first too- and I had never "hacked" a phone before this one. Now, it's so easy the biggest problem for me is getting ahead of myself and forgetting/missing a step. lol
    I'm not trying to talk down, but to boost your confidence.
  17. Thread Author  Thread Author    #17
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Nook: CM7.1
    I'd like to try flashing a rom, but no drivers i download work and I can't seem to connect to samsung customer support.
  18. #18
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    MIUI 1.9.23, stock
    what version of windows are you using?
  19. Thread Author  Thread Author    #19
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Nook: CM7.1
    Default
    Quote Originally Posted by kcrandall758 View Post
    I'm using Windows 7, I think 32 bit because I downloaded the 64 bit international Galaxy S drivers trying to see if they work and they said they where incompatable
  20. #20
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    MIUI 1.9.23, stock
    I never had a problem with my Win 7 32 bit installing the drivers for my Cappy when I had it... when I get home, let me see what drivers I have and where I DLed them from, and point you in that direction.
