Results 1 to 1 of 1
    radmanelite's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Angry Charging/Battery Problems
    I've had this phone for 2 years now, and aside from some minor stuff, it was great for a first smartphone. Starting a week or so ago, my Captivate i897 starting having multiple problems, all stemming from when I had to replace the SIM/micro SD card tray. After opening and closing the phone multiple times to replace the tray and fix a stuck volume rocker, it powered up just fine and was working (I thought) properly. I left it charging on my computer overnight (as I usuallly did in the past). The next morning, my phone was completly dead. Plugging the phone into multiple chargers would only cause the charging screen to flash for an instant then turn off.
    I tried multiple chargers and batteries until one battery powered on the phone. Unfortunatly, now the phone gets very warm (120 F) while idle, and the worst part, won't charge. In fact, charging severly drains the battery (went down 5% in 30 seconds).
    I am really at a loss for a solution. The few searches I could find for this problem only said to change the batteries and chargers, which I have done. The only thing I leave on is WiFi, and I constantly task kill apps. I'm about ready to switch from this phone, as the poor battery life (before these problems), sluggish performance and other misc. problems are fustrating me.
    Someone, please help me!
  1. [PROBLEM][SOLVED] Charging Battery on New CM9 ICS by thekraven
    By PatrickAkridge in forum LG Optimus S Rooting, ROMs, and Hacks
    Last Post: 02-19-2012, 09:31 AM
  2. Battery problems, won't charge. Looking for advice
    By jmusso in forum AT&T Captivate
    Last Post: 11-18-2010, 10:31 AM
  3. Charging Battery Slow
    By Umass021 in forum Motorola Droid
    Last Post: 03-18-2010, 08:09 PM
  4. HTC Hero (Seious battery problems)
    By tomwazza in forum HTC Hero
    Last Post: 12-19-2009, 09:29 AM
  5. Replies: 3
    Last Post: 12-14-2009, 07:44 AM
