1. mrneedstuff's Avatar
    I was going to flash a new rom to my Captivate. So, I figured, why not just format everything and then install it (stupid...). So I did just that. I have CWM Recovery and formatted all the folder. Now, my phone cannot load. It is stuck at the screen that says "Galaxy S GT-I9000 Samsung". The four buttons at the bottom don't light up, I can only use the 2 volume buttons and the power button to restart the phone. I cannot seem to get it into download mode or recovery mode. Help! Please!!! I have some very important text messages I need to receive and send!
    How can I fix this?
    01-26-2013 10:40 AM
  2. mrneedstuff's Avatar
    I feel even more stupid. After spending much of today trying to get my phone into download mode, I finally have. It is working at least for now. I would request that this thread be closed. Or do I have to request /close or something. IDK
    01-26-2013 06:36 PM
  3. unglued94ta's Avatar
    Glad you got it working again. If you are using the Android app, Just click on your name of you original post and touch "more". Then there should be an option to report it. Just type in "problem solved, please close thread".
    What ROM have you decided to go with?
    Sent from my GT-N7000 using Android Central Forums
    01-27-2013 03:31 PM
  1. WEB page load problems
    By Dramer77 in forum AT&T Galaxy S II
    Last Post: 10-09-2011, 05:43 PM
  2. Droid X2 Homepage Loading Problems
    By DROIDFANX2 in forum Motorola Droid X2
    Last Post: 06-22-2011, 07:31 PM
  3. Apps on SD loading problem
    By _Zguy__ in forum AT&T Captivate
    Last Post: 12-17-2010, 01:54 PM
  4. secure site loading problem
    By tazzy695 in forum T-Mobile G2
    Last Post: 11-26-2010, 07:59 AM
  5. Google Maps loading problem with GPS-Need help.
    By arcane#AC in forum HTC Hero
    Last Post: 12-13-2009, 05:18 PM
