1. Kjdadada's Avatar
    Are there LED indicators on this phone? I see two area at the top of this phone which one looks like it could be an LED but I have never seen it work???
    09-22-2010 02:56 PM
  2. JackImageX's Avatar
    There are no LED's on the Captivate.
    There's an app in the market called NoLED. It will display notifications on the screen if you get a mail, etc. But, I've found that it does take a bit of your battery life because the screen is running when a notification goes off.
    09-22-2010 03:14 PM
  3. Kjdadada's Avatar
    Thank you...I didn't think so but I was just curious about those two clear spots on top of this phone.. Maybe light sensors?
    09-22-2010 03:20 PM
  4. Cagey48's Avatar
    One is a proximity sensor the other is probably some sort of ambient light sensor.
    09-22-2010 03:33 PM
