Results 1 to 7 of 7
    ap1618#AC's Avatar
    Posts
    ROM
    di11i's 5.6 stripped
    Default Best GPS fix Settings please?
    Hi, Can someone please post the best fix for the GPS issues on the captivate, using the LBSTestMode fix?
    (I cannot seem to install the new updtate just released... yet...)
  2. #2
    Default
    these settings work the best for me
    menu, settings, Location and Security,
    check/enable ‘Use Wireless Networks’
    Go into LbsTestMode (*#*#1472365#*#*) (using phone dialer)
    Go to Application Settings
    Enable MS-Based Mode
    Increase Accuracy to 100
    Turn Skyhook on
    Return to the main LbsTestMode menu
    Go to SUPL/CP Settings
    Select the Serve FQDN Type drop down menu
    select AUTO Config
    Exit to the dialer and reboot
    for faster locks turn wifi off
    mine usually locks in 10 seconds or less
    tracking seems to work fine driving around town
    note:
    you can also add a shortcut to lbstestmode if you have launcherpro
    press screen and hold
    shortcut.. activities.. lbstestmode
    ap1618#AC's Avatar
    Posts
    ROM
    Default
    thanks. I tried it and it worked like a charm the very first time. afterward it has the same trouble locking on to a fix. It locks and loses lock soon...
    any idea why?
  4. #4
    Default
    FYI... this thread has steps that worked for me.
    http://forum.androidcentral.com/t-ca...ota-patch.html
  5. #5
    Default
    i've found it holds a lock driving around town for me
    BUT
    I have noticed that A LOT of things seem to not work as well
    the longer the phones been on... if you monitor your free memory in
    task killer you'll see it gets lower and lower as some apps dont seem
    to release memory when you kill them..
    at some point many things can quit working
    pop email.. not gmail but the other one
    even being able to make a phone call i've seen
    at that point nothing to do but restart...
    you might also try the alternative settings in the link
    ap1618#AC's Avatar
    Posts
    ROM
    Default
    do you mean this memory hog happens AFTER the firmware update?
    Quote Originally Posted by bobaka View Post
    BUT
  7. #7
    dayv's Avatar
    Posts
    Default
    BUT
    Uninstall your task killer - don't use task killers or do any arbitrary stopping of the services running in the back ground - and I bet after rebooting your phone twice you will find your phone running better for longer periods of time.
    After I installed atk and stopped trying to continually maximize my available memory manually my phones performance was much better and my battery life even improved.
