Results 1 to 8 of 8
    Default oclf fix help
    I am doing ryan's fix on the captivate but am getting stuck after the reboot.. I scroll down in recovery mode and ther is no "appl sd card update to selcet..... any help ?
  2. #2
    Default
    If your doing root just select reinstall packages and hit power button to confirm selection
    Sent from my SAMSUNG-SGH-I897 using Tapatalk
  3. #3
    Default
    you should really check out the voodoo lag fix - it is better solution. It is the only one packaged with any of the custom Roms.
  4. #4
    s2h2golf's Avatar
    Posts
    Global Posts
    239 Global Posts
    ROM
    2.3.4 / Stock
    Default
    Quote Originally Posted by alphadog View Post
    If it's not available from the Market, the majority of users will not use it. I tried the Cognition ROM and was not that impressed over my stock phone running the OCLF. My quadrant scores were higher with OCLF and the phone wasn't buggy as it was with the custom ROM. Also, to get rid of the OCLF lagfix, I didn't have to flash back or know how to open an adb shell to turn it off. Don't get me wrong, I like changing up my phone, but at the end of the day if I want it working as smooth as possible, I always go back to stock with OCLF.
    Motorola Droid > HTC Aria > Samsung Captivate (Serendipity 7) > Virgin Mobile Optimus V (CM7) > Motorola Atrix > HTC Flyer
    Default
    thanks for the help, it is working very smoothly and very quick....
    Default
    ok now after successfully doing the oclf fix, when I plug the captivate into my comptuer the usb icon noi longer shows up in the upper left hand corner of the screen so I can no longer transfer files as mass storage??? any help for this ?
    Default
    after unrooting and undoing the fix and restarting a few times I can now mount the usb ok and transfer files.... anyway to have a oclf that does not stop the usb from moutnig ?
  8. #8
    Default
    check out voodoo lagfix on XDA - it works perfectly
