Ross#AC
Even though this phone has some issues I think the wifi is pretty good.
Do you have a lot of data on the phone? I'm guessing not, since you've been having so much trouble with it.
Have you tried a factory reset? It will delete everything on the phone but it will restore all the defaults. It may be something to keep in mind.
I'm tempted to say it's a hardware problem but you said it does connect to other AP's, right? If so, hardware is ok.
Did you ever get it connected to your own network?
Ross
Ross
